how hard would it be to put a floor hatch in my house?
Discussion in 'The Lounge' started by boggerless, Nov 3, 2006.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    that little hole in the block sucks to work through and i need to jack the floor up. we did it 9 years ago but the **** is starting to sink again. i need to put in cement pods and thats a pain with a 1ft by 2ft hole.we sell roof hatches at work but i think that might be a little dumb looking.:haha:
  2. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Easy stuff. Pick a closet, cut between the studs,, then when you have a hole and can see what you are doing, trim the edges. Then nail a chunk of 2x material to each inside edge of the studs, for the hatch to rest on.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You're gonna be hiding illegal aliens in your crawl space now? :D
  4. boggerless
    May 26, 2003
    22,728
    96
    i knew i shoulda asked you bro.:haha: winter is coming and i'm taking the lay off so i'll have time.thanks
  5. boggerless
    May 26, 2003
    22,728
    96
    no my neighbor does that.:haha:
  6. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    No, he's doing a dungeon for his sex slave:D
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the chick from the grocery store?
  8. Corey 78K5
    13,055
    Humboldt County, CA
    I figured it would be something that walked on all fours:doah:
  9. boggerless
    May 26, 2003
    22,728
    96
    whats cool is there is a closet close to the main dip.how should i start,i remember you told me aboot the string to find level. but should i start in the middle and work out or start on one end and work over to the other side?
  10. boggerless
    May 26, 2003
    22,728
    96
    :haha: :haha: :haha: :haha:
  11. boggerless
    May 26, 2003
    22,728
    96
    not yet.:D
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    RJ? :o
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    well make sure to post up when you're bare assed, buns up on the downstroke. we'll need pictures (without you in them) shortly thereafter.
  14. boggerless
    May 26, 2003
    22,728
    96
    i'm boggerless not fumes.:haha: :haha: :haha: :haha:
  15. boggerless
    May 26, 2003
    22,728
    96
    :haha: Don will have to fix the pic. maybe a tea bag pic just for laughs??
  16. boggerless
    May 26, 2003
    22,728
    96
    THAT would be scary:eek1:
  17. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Step 1-remove the floor covering in the clost, so you can see the nails holding the subfloor down.
    Step 2-Make 2 parallel lines just inside the nail lines
    Step 3-Mark where you want the end cuts to be.
    Step 4-Set the blade depth on your saw to just less than 3/4".
    Step 5-Start cutting,going past your corners by about 1 1/2 inches.
    Put a couple of wood screws in the subfloor, leaving about 1 " above the surface, so you have something to pull on and lift the piece out.
    Make DAMN SURE there are no wires or plumbing where you are cutting.:doah: :doah: :doah: Have fun!!!!!!
  18. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Wow! All this high tec stuff to put a hole in the floor?????
    You know what to do.... Drill a 1/2 " hole in the floor get out the sawz all with a 12" wood blade and go for it. Yee Haaaa!
  19. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Isulate that hole after yer done...
  20. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I can come out through any floor I please, thank you
