How hard would it be ??????
Discussion in 'The Garage' started by Z3PR, Nov 25, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    How hard would it be to put 3/4 Ton axles in a S-10 4x4 Blazer ??? I've seen V-8 conversion, but never seen the whole drive train (motor, transmission, transfer case, front and rear axles) from a 3/4 Ton truck swapped into a S-10. Would the front axle need to be narrowed ??? Might make an intresting trail rig for those tight j@@p only type of trails. What do you think ????
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    ive only seen it where they swapped a s10 body onto a k5 frame.looked pretty kewl.
  3. Grim-Reaper
    7,385
    Atlanta
    It can be done and has been. Problem is shoe horning a V8 in where a V6 use to live.
    Customer spring mounts on the front and relocate the purches on the rear. Run a set of hummer rims to help narrow it down a little and to help with fender scrub. You cant cut but about 2 inches off the fender on a S truck before your into floor board.
