How high is too high?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, Mar 17, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    approach angle that is
    going up a hill yesterday and engine started dying (gas not gettin up there?)
    any way to fix this?
    any advice?
    should i back up the hill?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Waht carb are you running? Maybe the floats are set low. How much gas did you have in the tank?
  3. tecton
    Dec 1, 2002
    1,553
    WV
    tank was about 3/4 full
    i have an edlebrock 600cfm performer series...
    the box says non-emission...does that mean its not legal?
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Try getting the offroad kit for the carburator. If they dont do underhood emision inspections where you live I wouldnt worry about the non-emission thing.
  5. tecton
    Dec 1, 2002
    1,553
    WV
    rgr thnx
  6. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    definatly go with the offroad kit. My edelbrock would stall out at minimal angles. I now have a quadrajet and have had no real problems yet.
  7. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    an over dose is to high I would suppose ......? No for real i too run an E-brock and the spring loaded seats are a must for any angles you also change the float level a little as per Edelbrock's suggestions , Good luck /forums/images/graemlins/thumb.gif
