How high will I be with a 4 inch lift.
Discussion in 'The Garage' started by tch777, Oct 12, 2005.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    I have some add a leafs right now, but I think they have sagged badly.
    I don't know anyone with a stock Sub either.
    Can anyone give me some height measurements so I can estimate how much actual lift I will get with a 4 inch all spring lift?
    Is there a spot we can measure from on the frame so tire size doesn't matter?
    Tim
  2. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    welll with a 4" lift i have.. blocks rear springs front and 33" mud terrains i can JUST sneak under a 7ft parking garage bar.. basicaly by 2-3"...
  3. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    i have a 4" and 35's and havent found a homegarage it will fit in yet. i would measure the top of the wheel well to the hub that dont factor in tires
    balzer
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Top of the axle tube to frame should be a real number. Or, like mentioned, hub to wheel well top lip, but it has to be un-trimmed in that area.
    Is your concern that it will be too much lift? Your sig says you have 33's .. a 4" lift w/ 33's looks pretty sweet to me. :dunno:
  5. tch777
    Jan 15, 2003
    244
    I will be going to 35s.
    The sub doesn't fit in the garage now but that is cause it is full of tools.
    I am just wondering since I have the add a leaf but I think the springs are still sagging badly.
    I thought a 4 inch would add about 2 inches height over how it sits today, but now I am wondering if it might actually be more than that.
    Is there anyone with a stock 1/2 4x4 sub that can measure the hub to wheel well?
    Tim
  6. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    It depends on how much you smoke. :rolleyes:
    -Harrison
  7. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I would think it would only be about 2". It could be that your springs have sagged some.. but sometimes you just get used to the lift, and it appears to be lower than it is. I doubt you would see more than 2", and if you did, it would be very minor.
    Granted, I'm not saying it will fit in the garage.. I don't know, but I doubt it.
  8. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    your 4" springs will sag soon after if you're carrying tools or a heavy vehicle like a suburban, so I'd only bank on it lifting you about 2" over current height
