How I did My 3" wide Ford 57's
Discussion in 'The Garage' started by Corey 78K5, May 10, 2004.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    How I did My 3\" wide Ford 57\'s
    Some of You may know that like a few others I chose to use the 3" wide 57" Ford Bronco springs over the more populer 2.5" 57's. The main reason was they were a 5 leaf pack that I feel will hold up better to the weight of the Blazers toopper and cause I have heard from other about sagging problems with the F-150 packs.
    First off I'm cheap so I used a front/rear hanger from an 84 dually for My flip.
    I then welded half of a Chevy shackle to half of a Ford shackle. Actually it was a little more than half of each one ending up with a shackle that was 5" long
    I used the stock front hanger and had a spring shop narrow the first 3" of the spring (just like a stock front spring) I thought about using a Ford Hanger but that would have moved the center line of the springs out 1/2" from the frame creating alinment problems with the center pins and the axel pads.
    So far it works really good but I have not gotten a chance to really test it out due to the fact that I need to upgrade My break lines and do the crossover steering to really test the flex on it. I also mocked it up and still need to replace all the bushings and paint it all.
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Re: How I did My 3\" wide Ford 57\'s
    Nice work and good write up! /forums/images/graemlins/thumb.gif
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Very nice!
    I hope that helps with the saggy butt problem.
  4. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    what year bronco have those springs
  5. Corey 78K5
    13,055
    Humboldt County, CA
    I got Mine off of an 84 Bronco, but any full size 80's-90's Bronco will have them and from what I have seen 4X4 F-150's of the same era will also have them.
  6. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Got mine from an '85 f250 diesel
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Looks good. I like the idea of the Bronco springs for the little extra. Looks like you need to hack up that 14bff too. /forums/images/graemlins/thumb.gif
    Harley
