How I mounted my Art Carr shifter (pic)
Discussion in 'The Garage' started by CK5, May 6, 2004.
  1. CK5
    May 19, 1999
    21,624
    702
    CO
    I couldn't find anything on the web on how I could mount my AC shifter that would work for me so what I ended up doing was makeing a cardboard cut out of an off-set triangle with a 1-3/4" half radias at the bottom to mount to my seat tube, I then took my template to a large steel house and for 5.00 per bracket they laser cut out my two pieces. I got rid of the plastic houseing that came with it and mounted it right where I wanted it, used 1/4" plate and it does not move AT ALL, something I was worried about because it was so tall and skinny at the bottom, but turned out perfect, when in 1st/2nd the shifter is straight up and in perfect reach for me. /forums/images/graemlins/thumb.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Looks nice /forums/images/graemlins/bow.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    VERY NICE. I like it. /forums/images/graemlins/pimp1.gif /forums/images/graemlins/waytogo.gif
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Looks good.
    You need to add another shifter closer to the passenger seat. If someone asks what it is tell them it's the emergency eject lever for the passenger seat. That'll keep 'em on their best behavior. /forums/images/graemlins/rotfl.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah there aren't enough levers, needs ox lockers, some manual line locks, a fuel shutoff or two, battery disconnect in cab, hmmmm anything else? rear steer lever maybe?
    Nice mounting setup by the way.
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Wow, sweet mount. I love that! Looks much sweeter than my elevated platform... <sniff>
    What's going on here, is there some weird psychic connection here? You and I are going to wind up with the same rig as soon as you ditch all that sheet metal. My Art Carr is scheduled for delivery today! /forums/images/graemlins/rotfl.gif
    PRPs (almost the same color), Art Carr, very similar cages, very similar drive train, identical axles, your recent comments about loosing the sheet metal and larger tires... /forums/images/graemlins/rotfl.gif I guess good parts is good parts...
  7. CK5
    May 19, 1999
    21,624
    702
    CO
    Yeah, but I'm better looking. /forums/images/graemlins/rotfl.gif I don't plan on doing anything major with the body, this summer at least, the wheeling season has just begun and it's time to get it awn. /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    looks awsome /forums/images/graemlins/waytogo.gif
  9. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    Looks like a perfect spot to mount some cup holders. /forums/images/graemlins/peace.gif
  10. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Nice fab work /forums/images/graemlins/thumb.gif I am not familiar with what the shifter is for though /forums/images/graemlins/thinking.gif I see your doubler sticks below/forums/images/graemlins/rolleyes.gif
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    auto trans /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  12. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    so did you remove the steering column shifter and if so how does that work? I suppose you'd have to remove it. Just not sure how all that works.
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, that aint saying much, but I'll give that to ya... /forums/images/graemlins/bow.gif
    As for how it works. Yes, it replaces the one on the column. Minimally, you can just remove the linkage from the lower column down to the trans and knock the roll pin out of the shifter handle to get it off the column and out of the way. If the little stub thing left on the column bothers you enough, you can swap the collar (or the complete column) using a donor from round column car with factory floor shift, or a manual trans truck.
  14. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    that is what I was thinking with the manual trans column. thanks for the info.
  15. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Thats nice looking. Them seats are nice too. Thinking of that route with mine. /forums/images/graemlins/thumb.gif
  16. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I used a tilt column from a 4sp truck. Otherwise you could cut and fill where the lever went.
  17. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I am thinking this may be in my future.
    Some time after the narrowing job which will begin on Sunday. /forums/images/graemlins/peace.gif
  18. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    nice fab work! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  19. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    nice work! art carr is the bomb! don't waste money on anything else! /forums/images/graemlins/thumb.gif
  20. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Nice! /forums/images/graemlins/thumb.gif
