How Important Is Is To Seperate Power And Signal Cables In Amplifier Wiring
Discussion in 'Audio' started by Resurrection_Joe, Dec 14, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I have to pry out a lot fo moulding with a freaky psyco tool to run amp wiring in my 2003 Malibu, so I'd like to keep that to a minimum. So is it that important to run power and signal on opposite sides of the car? It'd be twice the work for me. It's only going to be bass frequencies if that matters.
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    You have a Malibu? Since when! I thought that was a truck, with a canopy?
  3. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I traded that in for the Malibu
    It's a lot more reliable, and I still have the rock truck and the K5
  4. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    I'd run them both on the same side.
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yes, but why ?
  6. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    The main reason for running them on separate sides is to reduce engine noise. If you are using quality stuff you shouldnt hear any noise if they are right next to each other. Good Luck
    Adam
  7. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    Its a hell of alot easier to just run them on the same side. I have done it in every system i've had and never heard engine noise or anything.
  8. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Okydoke, thanks
    Just put the deck in the dash kit and it's NICCCCCCCCCCCEEEE
    It doesn't use the sleeve or the trim ring, which really cleans it up
  9. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    what deck did you get?
  10. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
  11. fordeater
    Mar 21, 2004
    1,402
    Missoula, Montana
    i've got that same deck sitting in my guest bedroom. I love pioneer. Its one of my favorite car audio brands. How many subs are you gonna have?
  12. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    The two MTX4000 12" I had in my K5
    I could use the Pioneer 305SVC 12" I had in my truck but I don't think I'd like that as well
  13. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Crap! You didnt order it from crutchfield though did you? If you guys need any audio stuff I can get you a much better deal than through those guys (No offense intended Resurrection_Joe). I cant always beat the price hacks on ebay but I can beat crutchfield 99% of the time.
    adam
  14. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    It is not so much noise as it is interference. Electrical current has a frequency band like a signal input does. I have had humming come through speakers because I laid the amp power wire next to the speaker wires. Engine noise went out about 25-30 years ago with the advent of electronic ignitions and shielded plug wires.
  15. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Nah, I bought off Circuit City because I have one of those cards
  16. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i wouldnt say engine noise went out. i just installed my system, power and RCA's on opposite sides, everything done correctly and i've got a little motor noise. my buddies have had similar problems. i've got to go thru all my connections and amps and see where the problem is coming from.
    for subs i dont think i would bother routing on both sides. usually you only here the buzzing or motor sounds when running mids and highs thru an amp.
  17. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I ended up running them on seperate sides
  18. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    you are right...as far as bass frequency and signals are concerned you are not gonna get engine noise or alternator whine...it normally only becomes an issue with a 4 channel or 2 channel that is running mids or highs...in which case they say run them at least 18 inches apart
  19. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    They should be run seperate at least 12 in apart. Power should be run down the same side as the battery if possible. And if you have to cross any of the factory wiring it should be done at 90 degrees. Engine noise is normally brought in by the ignition wires. A bad ground can also cause noise. You should run a ground cable from the engine block to the firewall (this also helps with other electrical problems).Sometimes the body does not have a strong ground due to rust at mounting points. Remeber, ground is your friend and should be 18in or less.
  20. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Well gee, it's been installed for a month, but thanks
