how important is the
Discussion in 'The Garage' started by surpip, Apr 20, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    little plastic vent tube on the top of a 700r4?
    mine is busted off flush
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    as long as you don't do a lot of deep water you should be fine
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ive never hooked mine up, but then again, my 700r4's dont last long enough to make a difference anyways.
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    there's a vent tube?? i should find that.
  5. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I accidentally broke mine off flush too but I JBwelded a piece of hard brakeline up against the hole and attached a hose to it.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i took the end of the hose and gooped a crapload of black RTV around it, so i hope that works out:)
  7. afroman006
    Aug 21, 2002
    2,876
    When I rebuild this tranny I'm planning on drilling the remaining plastic stub out of the hole and either JBwelding the piece of brakeline in the hole or getting a small screw in barb fitting for it.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    wowow
    that ****er is never coming off
  9. afroman006
    Aug 21, 2002
    2,876
    :D For some reason I didnt come up with this idea till it was in the truck. JB weld is kinda runny and I had to build up like 1/4" to make the brakeline line up with the hole. I ended up using like half of an entire package on that damn thing :haha:
