how in the world do you fix this...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Feb 22, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    ok guys...
    I asked this awhile back, and I got the answer; problem is I never fixed it at the time, and now I can't remember. I also couldn't find the post.
    the latch on my glove compartment is loose so it jiggles and drives me nuts. I went to fix it today, and can't remember or figure it out.
    how to I tighten that @#^%& latch! [​IMG][​IMG]
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,395
    E-town baby!
    Just weld it shut...you don't really use that glovebox do you?[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    I had the same problem. I think this is what I did. Open the glove box, turn the latching mechanism on the inside clockwise (to tighten it). I think the outside chrome knob moves along with it. It can be difficult because it has to go a full turn, sometimes two. I'm not positive this is what you need to do, but I think that is what fixed mine.
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea no bigger then I wouldn't have to worry about servicing my computer or anything like that either! [​IMG]
  5. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    You might try this-Take the catch off waller the holes out so you can slide it back a little to tighten the whole thing up.
    Just dont blame a broken drill bit on me.
    Later,
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    ??? in english? (please [​IMG])
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    If you insert the key and turn it and pull at the same time the lock cylinder should come out. Tighten what looks like a hollow nut and reinsert cylinder. Should work. Hope this helps.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hold it shut with some bubble gum. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Those suckers will drive ya' nuts.
    I just fiddle with it until I can keep it shut. AND NEVER TOUCH IT AGAIN. (I need to get Jeff 427 to make me a "Don't touch this" sticker for my glove box [​IMG])
    <font color=white>.</font color=white>Eric
    <font color=white>.</font color=white>Twizted
  10. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    The roll bar holds mine shut 'cause the screws vibrated out. One of these days I'll take it out along with the rest of the dash and build a custom bare bones dash like they have in race trucks.
    If you knew the truth, you too would be against marijuana prohibition!
    Blue '74Blazer Topless W/ 35 BFG Muds1" Body Lift W/ Energy Susp. Bushings
  11. 73 Heavyd
    73 Heavyd Registered Member
    Jan 28, 2002
    38
    South Dakota
    Shawnboy is right, but on earlier styles there is a turn mechanism with only a tiny hole in the center. Just insert a paperclip until the turn mechanism separates from the latch. Then you will see the hex style nut he was talking about to tighten everything up. Keep the pin in the turn mechanism so the tumblers are easier to reinsert after it's tightened.
    Paint is so overrated!
