How install crank timing gear?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Jan 1, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Anybody got any ideas how to install this sucker? Would it be okay to use a large socket and a bolt in the balancer hole and just press it on in this fashion? Or should I just use an oversized socket and a dead blow?
    Thoughts, gents?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    i always just started it by hand as much as possible then take a smooth faced finish hammer (medium size) and tap one side then the other side gently until it finally bottoms out. takes a couple minutes but works good.. lubing it first with a little motor oil would be good
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I have a piece of pipe that fits over the snout and then a few whacks with a hammer and it is a done deal.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I have a tool used for installing the harmonic balancer, it screws into the end of the crank and pushes the balancer on, costs about $25, I put a spacer between the gear and the tool and it pushes it on, saves pounding on the crankshaft, and thrust bearings if it's in the block.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
    See My Toys: <a target="_blank" href=http://community.webshots.com/user/wdb172454>http://community.webshots.com/user/wdb172454</a>
  5. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    BINGO !!!!! That's what works for me......
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  6. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I took a 2x4 and drilled some holes in it so the crank snout could pass through it and used my steering wheel lock plate (it was handy as a big washer) and just put the balancer bolt in and tightened it real good.
    You should try to avoin baning on the crankshaft cuz it could mess up your seal but i hammered my balancer on and i havent had any trouble
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
