how is a body lift set up?
Discussion in 'The Garage' started by bryguy00b, Oct 19, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    like the question says..and can i do it right while im putting new body mounts in too?
    thanx
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    yeah you can, when you jack up the body to swap the bushings jack it an extra 2-3" and put the puck in at the same time.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    now would i have to worry about the steering arm shaft or anything getting messed up?
  4. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Just follow the step by step instructions with the body lift kit, they will supply the shifter extension and tell you about the radiator shroud.
    Bill
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok..well i think im ganna go ahead and order it when i get to lifting the body of. ganna take the cap of..and all the mounts and pull the rear end of the body up with some heavy rope or something, that way while the floor is out ill be able to paint the frame like i wanted to.. then put the new floor parts in and then lower it back down on the new mounts and lift pucks..
  6. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    How much of a boy lift are you going?? I have a 3" (slightly toasted /forums/images/graemlins/crazy.gif) body lift. Here were my problem spots... Fan shroud had to be cut out at the bottom. Steering column had to be lengthened. This I did not realize till it was to late and i screwed up the column and had to do all kinds of playing around with it. Tis best to just be prepared to lenghten it. Gap between rear bumper and body. I got a peice of diamond plate aluminum and bent it...from under the rear bumper to the bottom of the tailgate....looks good, cheap and easy! If you plan on going with a suspension lift to, then you got to get into changing the pitman arm and all that. Oh yea....while they say you do not need to replace your shocks....replace them with longer ones, or you will loose all articulation. Hope this kinda helps. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    it does thanx a lot! also did you have any trouble with your tranny shifter or t-case shifter?
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The tranny shifter, depending on how much of a body lift, you might have to lengthen it. On my 2" i could of gotten away with not lengthening it, but I did anyways (all depends of the shifter rod)...the t-case thing, you might have a little trouble(depending on the t-case and linkage setup) on mine (203) I didn't have to do anything, on others you might just have to adjust the linkage or you can cut the hole in the floor a little longer to give the shifter more travel to engage the t-case.
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    but no problems with the tranny lever on the column? did you have to pull the steering wheel out some or somthing?
  10. trouble1
    Sep 28, 2002
    346
    yup-- I forgot aabout that...I have the 208, and had to oblong the hole a little bit. Only about a half an inch or so. The factory trim still covers, had to move it forward a little. Sorry I forgot, my brain is somewhere else. /forums/images/graemlins/tongue.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    No problems what-so-ever. On my 2", all i did was unbolt the steering column from the dash and lowered it down, took off the shifter rod that goes down to the tranny, put in my lift, mounted the steering column back up and installed my new shifter rod that I made (pics in my webshots of new shifter rod) and was just fine. Some people will say to melt out the plastic pins in the steering shaft to help lengthen the shaft, I didn't do it, but i am going to go back and do it later when i find the time LOL.
  12. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how do you take the shifter rod for the tranny out?
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    there is a single bolt/sleeve on the bottom of the rod and at the top where it attaches to the column, is just a pin and washer and pull it out. very simple
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok i c thanx!
