How is your exhaust routed????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fad2blk99, Feb 18, 2004.
  1. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm getting some headers but I'm unsure of how I want to run my exhaust... I want 4-into-1 long tube headers like I had on a previous Blazer, but you either have to run straight duals or make your Y or X pipe after the t-case… As I understand it, you need to mount your balance pipe (in my case a Y pipe) as soon after the collector as possible; mounting behind the t-case (correct me if I’m wrong) seems a little too late in the exhaust flow to take advantage of the increase in low-end torque a balance pipe should give you. My other option would be to go w/ an intermediate length header and run a stock style Y pipe…..
    I’d like to get your thoughts on this and see how some of ya’ll have run your exhaust.
    Thanks!
  2. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Here's mine..
    Hedman Headers..
    2 1/2" Duals w/50 series Flowmasters...
  3. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Nice work... /forums/images/graemlins/thumb.gif
    I might go that way if its too much trouble to go the way I have in mind now. I'm trying to go 2.5" from the collectors to a single 3" Y pipe to a single 3' in dual 2.5" out 50 series flowmaster.
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Hooker comp headers, dual 2.5" pipe, 40 series flowmasters, 5" tips.
  5. Jays Beast
    Jays Beast 1/2 ton status
    Aug 7, 2002
    538
    Chandler, AZ
    My exhaust goes from collectors with 2.5" pipe to a 3"Y to high flow 3" cat to 3" glass pack then 3" out the back.
    [​IMG] [​IMG]
  6. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    I don't have pics right now, but my exhaust looks identical to JK5's. I'm running Dynomax long-tubes with 2.25" duals back to 40 series Flowmasters. My crossover is right where JK5's is. I did have to drop the crossover just a little bit after the 6" lift to give plenty of clearance for the rear driveshaft. Everything still tucks up pretty nice under the truck. I think having the crossover pipe up closer to the header collectors would be better, but I just couldn't see how to route it so I did it this way.
