How keep water out of the carb?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Feb 12, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Okay, now that I have my new engine and my new open air filter and 5" K&N, I have a question...
    I am running a competition in a few weeks that includes a deep mud run. I am confident I will be sloshing a lot of water up and into the engine compartment either by the tires, the fan, or something. What would be the most COST-EFFECTIVE way to protect my carb and air cleaner? It will not be submerged, so I don't need a snorkel. Are the K&N pre-filters really worth it? What about some sort of "shield" on the front and sides of the filter that attach to the air cleaner somehow?
    Thoughts, please?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    sheet metal. make a spacer that bends round both sides and front. but not the back. then bolt it in under the carb. if you use anything thick use 2 gaskets for your carb. thin you might be able to get away with it. OR put your inner fenders in.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I have my inner fenders in place. but, when I hit a pit professionally dug for 38"+ tires, I am sure to get a lot of splash up and into the engine compartment. Last time I was out in the mud playing, I got mud splatters on the underside of the hood. So, I am just trying to protect. I want something easily removeable to keep from restricting airflow in the sand drag and obstacle course events, but I want it protected during the mud bog (the first event of the day).
    Brian
  4. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    the prefilter keeps big globbers out, but as far as water and stuff, let me know when you find something that works [​IMG]. You might make sure that gap from your body lift is covered..you know by the frame?
    <font color=green>Can't sleep...the clown will get me</font color=green>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Stop by the junk yard and get an old air filter assmebly and just cut it as described above- cut the back out of it.
    If you go to the parts store and look at the mudflap section they often have 'cut your own' flaps. Rectangle pieces of rubber. You could screw these to the inside of the fenders and maybe one under the fan shroud to deflect the goo. On the road I have the air filter lid upside down so it can breath better but whenever I run offroad I always flip my air cleaner lid back the way it's supposed to go. That way it doesn't matter how much splash there is the filter will stay dry. Good luck in the competion.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    go to the junk yard and get a stock filter asembaly(sp?) cover and run it in the mudbog and then put your k&amp;n back on for the rest of the day
    wheeling pics
  7. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    If this is just for the mud run only and temporarily... to protect the front nd sides...
    Duct tape!!!
    Cheap as can be, and works. I have done this.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  8. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    make a snorkel for it. you can go the arb expensive route or make one out of pvc.
    good luck!
    MTPockets
    MAD MAX: http://community.webshots.com/user/mtpockets35
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i wouldnt worry, the oil on the filter wards out any water besides complete submersion. thats what ive found
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  10. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I would have to agree with seventy4Blazer, a sheet metal shield should work well, I have a friend that did the same thing on his d@dge and it works like a charm. If you space it away from the filter element (1/4 - 1/2 inch) it should still keep splashing water and mud off the filter yet still let the filter breathe like it should. May be a permanent solution. You could also bring the front lip up almost to the hood to really make sure the fan doesn't throw any goo into it. Lets call it sub-hood cowl induction, haha. Just a thought.
    Pics at <a target="_blank" href=http://community.webshots.com/user/jlblmkh>http://community.webshots.com/user/jlblmkh</a>
    (Formerly heaj1)
    Swimmin like a rock, slingin like a stock, but not for long.
  11. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    With going though a lot og mud and water, especailly with a lot of wheel speed.... that little bit of oil on the filter will do NOTHING to keep the water out.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  12. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i have a k&amp;n open filament, and when i got to the car wash i leave the hood open and power wash everything with the engine still running. its never bogged down or studdered, and that is with water being forced into the element. even in offroad experience ive never had a problem. IMHO itll be fine
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hang a large piece of rubber from your front bumper if you're so worried. It will keep water from splashing up on your spark plugs and bogging out your motor.
    As for the air filter, get a cheap paper one. Replace the paper one with the K&amp;N when you're done 'bogging.
    Tim
  14. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I think what I have decided to do is to (a) get some strips of rubber to attach to my inner fender wells to act as shields from the tires (lips to cover the body lift gap). Secondly I will (b) make a shield for the air filter out of lexan (so it all still looks pretty, even covered in mud) that will protect the front and sides of the filter, leaving the rear exposed, and allowing about 1 to 1 1/2 inches of space around the protected part of the filter for good air flow.
    This should keep from restricting air flow too much, keep it "pretty", and keep it running. I will probably leave the shield on anytime I do an offroad jaunt when it is muddy OR really dry and dusty (the only two ways it gets down here in TX!).
    Brian
  15. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I know from experience that the oil in a K&amp;N filter won't stop water from entering the carb. JC Whitney sells a "Air Cleaner Shield" for a 14" x 3" filter for 7.99. The stock air cleaner assembly also sounds like an easy fix, one of these days I need to do this as well, but havent got around to it. Nothing like sucking a little water into the carb...lol
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The rubber hanging from the front bumper really works!!
    I suggest the K&amp;N Prefilter like you mentioned too in addition to the shield. I'm sure it will help, and it looks cool too.
    Tim
  17. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    There is a big differance between WOT and idle and sucking water in the intake. I have a 4 inch air cleaner sucked down to about an inch once, just going through some water.
    K&amp;Ns are a complete waste of money if you do a lot of ddep mud in my opinion. They get caked as easy as a cheapie. And you can never get all the dirt and grim out of a K&amp;N no matter how hard you try.
    Ken H.
    '86 K5 in parts
    1-ton 454 44 TSLs
  18. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    I'll second ken's K&amp;N water story. I sucked in water through it just from splashing up through the stock intake.
    <font color=blue>Brilliance is like 4wd, it allows you to get stuck in a more remote location [​IMG]</font color=blue>
