How long do i make my rear links for a 3 link
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dr_moneypit, Aug 14, 2004.
  1. dr_moneypit
    dr_moneypit Registered Member
    Jul 29, 2004
    23
    lonestar state
    i need how long my links need to to for a 3 link suspension /forums/images/graemlins/1zhelp.gif
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I'm sure most folks here will tell you it will be different for just about every vehicle. There are alot of variables to be figured in. So, its just not as simple as saying they need to be this long for this vehicle.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm about to guess you need more than just to know how long to make your links boss.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    how to make your tubes is simple, cut tubing, put in some tubing adaptors for your heim ends and weld the adaptors in. As for link length, it can really depend on where you can locate the links, you don't want short links, but really long ones will just get in the way. As for anything else, I'd say you should read up quite a bit on 4 links, and offroad suspension before you dive right into the project. http://www.akfabshop.com/alaskaoffroad/rear_suspension.htm
    there is a very basic writeup on a rear 4 link. Also I'd forget what rjfguitar said in the other post. Wishbone upper link is fine for street use but not great for offroading. Much better solutions out there.
  5. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    If properly designed the wishbone works great! Here is an example.
