How long do y'all wait for your oil to drain?
Discussion in 'The Garage' started by afroman006, Jan 15, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    How long do y\'all wait for your oil to drain?
    I just changed the oil in my burb and only got like 2 1/2 quarts out. I ran it for a minute then checked and the level was at the end of "operating" on the dipstick. I let it drain for about 10 minutes then took the filter off and drained for another 5 minutes. After it just dripped for awhile I stopped. Did I not wait long enough?
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Re: How long do y\'all wait for your oil to drain?
    You really shouldn't have to wait very long. Probably 95% of the oil should drain out within the first minute and then it will just slow to a trickle and than a drop.
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'm probably WAY overly anal, but when I change oil, I let it drain for about 5 minutes, then put the oil pan bung back in, put 1/2 quart of the new oil in and let it sit in the pan for a sec, then drain it as well. Then, I stick the air hose in the filler and blow VERY LOW PRESSURE air through to help purge the rest of the oil sitting in the pan. I know it seems dumb, but when I do this, even the fresh oil I run through it is dark from the gunk it has picked up.
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Pull the drain plug and while you wait for it to drain, check the rest of the vehicle over thoroughly. Grease what ever zirks you can find and kick all the tires and by the time you are done with that your ready to put the drain plug back in and fill it up.
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    there's always the ever popular beer break too /forums/images/graemlins/wink.gif
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ahh, well I just let it drain until it stops, one two beers it don't really matter, when it stops i wipe of the oil drool, plug the pan, insert new WIX filter, wipe up my mess off the driveway,add new oil......done
    So I guess to answer you question I wait about two beers worth of time. Now during the summer I may have to wait until 3 beers only cuz I am super thirsty in ht esummer time /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I like to change the oil right after pulling in the driveway, while the oil is still hot and the all the nasty stuff suspended in it hasn't had a chance to settle out. Most of the oil comes out VERY quikcly, then probably another pint or so will slowly dribble out over the next 5 minutes or so. While it's draining I take off the old filter and fill the new one with fresh oil.
    That's scary! Did you have oil pressure while the engine was running? Unless that engine has some serious sludge that's slowing down the oil so that it can't drain back to the pan, there should not have been anything left in the sump for the oil pump to pickup. /forums/images/graemlins/eek.gif
  8. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Then I must be SUPER ANAL /forums/images/graemlins/eek.gif
    I generally pull the plug, let it drain while I check the rest of the vehicle over and start greasing u-joints. Install the plug after most of it drains and remove the oil filter and let it drain. I then poor as much new oil into the new filter as possible and install. I take half a quart of new oil and put it down the passenger's side valve cover, and the other half down the driver's side. Go underneath and pull plug again and let drain while I top off fluids and finish greasing front end, u-joints, etc. Reinstall the plug, finish filling and start her up, get her warm, shut off, let sit and check level.
    Cheap Insurance
    Yes my friends say I am super anal...Oh well, I'm happy! /forums/images/graemlins/1zhelp.gif
  9. afroman006
    Aug 21, 2002
    2,876
    No not the "operating range" on the stick I mean the actual word "operating" lol. I'll check it again tomorow thx guys.
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    when you let it drain pull the dip stick out and the oil filler cap off the valve cover
  11. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    same here. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  12. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yeah, I forgot to mention that. That's a crucial step! /forums/images/graemlins/thumb.gif
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i let mine drain for 5 or 10 minutes and then put in about 3/4 quart of oil in the filter(after reinstalling the pan plug) and put on and fill up the engine and dont even check the level before calling it done /forums/images/graemlins/laugh.gif
