how long does it take to notice improper tire wear?
Discussion in 'The Garage' started by big_truxx, Jul 30, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    never thought about it before. how long would it take to noticeimproper tire wear? say i needed a front end alignment or whatever... how many miles on a new set of tires would i have to go before i could visually see?
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    if you've really got a problem id say it would be visible within the first 3k or so. IMO if you have any hint of stuff not being right, go ahead and align.
  3. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    It depends just how bad your allignment is out of whack.. I have seen brand new tires on a S-10 wear to the steel in less then 6000 miles.. The fellow said he didn't want to waste money on an allignment.. Do you want to be that fellow ? :D
  4. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Get a tape measure or some ribbon or something and check your toe in.
    If its outa wack then adjust your tierod
    If its not then start checking your ball joints (or kingpins)
    The correct toe in depends on your tire size, im not sure the coorect specs tho, i know someone on here does.
    Good luck
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    depends on how bad and what is off. Toe is the biggest wearer on tires and can wear and be noticed very quickly if its bad.
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    was just curious as i realized i have put at least (no less than) 2k on my burb and it had new tires put on just after buying... so i was thinking if anything soon would be the indication somehting is awry. but i have seen no signs that it is bad yet ;)
