How long does shocks last?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Sep 20, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have had my lift for about 3 years now,and was wondering when do I have to change the shocks?
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Your milage will vary, the good ol boy way to check is, to replace them every few years if they are on a daily
    driver. Other wise trade them in on a new model every other year. Also if they are filled with oil(most are) look
    at the seals and if they leak oil after you clean them, then most likely they need to be replaced.
    The above is my opinion only, your results maybe different.
    Good luck
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Yeah the Blazer is a daily driver...I will try that oil seal test,to see if they leak.....Thanks alot
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If you're not lazy, remove them and test each one to see how much resistance they still have left by compressing and expanding them with your hands. If one is too weak or had sudden weak points, it's time for a change.
    If you don't want to remove the shocks, just remove one end and test them under your truck.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  5. Executioner
    Feb 22, 2000
    1,530
    Will this test work for the one under pressure(i.e. Rancho 5000's, or 9000's) ?
    Thanks alot
  6. Blazer79
    1,816
    I don't know about the 9000s, but the 5000 steering stabilizer I just got didn't feel like it was under pressure. It was simply hard to extend or compress.
    I have the Edelbrock IAS and those really are under pressure. They are always pushing to be extended with about 50lbs of pressure.
    I've never seen a bad under-pressure shock, but I guess they simply stop pushing, so I guess this test will work for them as well.
    There's another simple test. You simply try to rock each corner of the vehicle. If one corner keeps rocking after you stop pushing it, the shock in that corner is ba (or too soft for your vehicle).
  7. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Good question...and since i sat thru an hour long class put on at the shop by Monroe here are some ideas...
    One...the obvious...signs of leakage. Two...drive the vehicle for 15 miles in different terrain...ie: lumpy city streets and smooth highways...then feel the body of each shock and compare the tempature to that of the frame....a shock that is dead will not generate any heat as the internal valving is not working. And this method is the simplest of all...plus it came straight from the manufacturer! I use a heat gun at work but your hand can feel hot or cold also!
    AZBLAZER
    1979 K5
    1976 K5 Chalet
    1972 K10 Suburban
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Steering stabilizers are not supposed to be pressurized! That is what differentiates them from shocks when the mounting features are similar. Think about it: If you had a single-stabilizer setup with a pressurized unit, the truck would always be pushed a little bit to the left and you would have to hold the steering wheel to keep it from drifting out of your lane on the highway. Now if you had two seperate stabilizers (not a dual unit one) with one on each end of the tie rod, you could make pressurized shocks work as long as the two units wore evenly.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The Rancho 5000's are not pressurized.
    Rene
