How long to rebluid np 205
Discussion in 'The Garage' started by pilgrim, Aug 3, 2002.
  1. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    I need to rebluid my 205 , i have the kit. About how long does it take to do the rebluid. Its my first time ripping apart the case , but i've got the brains so it should be easy. thanks
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I would set aside a day. I wire wheeled the shift forks and the shifter rails, painted the case..etc... Getting the Idler shaft to line up with the shims is a little time consuming.
  3. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
  4. pilgrim
    Sep 10, 2001
    247
    new hampshire
    THANK SO MUCH , YOU JUST SAVED THE DAY. HONESTLY I WAS JUST GOING TO RIP INTO IT WITHOUT A MANUAL, AND HOPE TO REMEMBER HOW THINGS WENT... BUT ALL THAT INFO , RIGHT AT MY FINGER TIPS NOW.. WOOHOOO. THANKS MAN.
  5. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    Just gave some info. from another CK5'er that I saw and saved. The rebuild is not hard at all you can also video tape yourself when you pull it apart it will also help. /forums/images/icons/grin.gif
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    there is another member with photos of the job that show more then my webshots albums.
    Leadfoot's pictures
