How low can I go (tire pressure)
Discussion in 'The Garage' started by SCOOBYDANNN, Apr 5, 2002.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    like it says
    How low can I go on 37x12.50's on 16.5x6.75 rim. the rim has a small bead rim, but not quite as big as the 15 and 16" rims.
  2. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I've aired down with 16.5s to about low 20s. My problem was rubbing rocks and actually peeling the steel rim away from the bead and losing air. Nothing a BFH couldn't repair on the trail. I do know that 1 pound of pressure is too low on a 16". I usually pull the valve stems on my 36x12.5 16"s and just let them go until they look right. Well, Driver's front was too low and slipped off the bead. First time for everything though.
    Juan
