How low can I lower my t-case and tranny?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TIGHTWORK82 K5, Sep 3, 2002.
  1. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    O.K. here is the deal I installed a six inch lift, my drive shaft angle was to steep in the rear (vibe over 55) so i used the spacers on the tranny brace and lowered it an inch aprox. fixed the problem. but I still had saggy arse in the rear. added add-a-leaf raised the rear 2" now vibe is back. can I lower some more to fix???? I was thinking longer bolts and some shock spacers. any ideas or fixes for this would be appreciated! thanks
    Mike /forums/images/icons/wink.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Some shims to correct the pinion angle would be a better way to go, IMHO.</font color>
  3. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    it has 6 " block can i use shims with the lift block?????
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The only correct way you are going to get both the working angle and the pinion angle correct is to install a C/V driveshaft. This is a common problem with short wheel base vehicles and lifts.
  5. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    where can I pick one up and for how much???
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Look up Jesse at www.highangledriveline.com He can hook you up with a rear C/V shaft. I am guessing somewhere in the neighborhood of about 450.00
