how low does your 2" clocked doubler hang beneath the frame?
Discussion in 'The Garage' started by yunit, Feb 1, 2004.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    how low does your 2\" clocked doubler hang beneath the frame?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Re: how low does your 2\" clocked doubler hang beneath the frame?
    Mine hangs down about 4"--BUT---i have a 1" drop for the crossmember and where i measured it the frame starts to move up. I dont know if the blazer frame does this as well.
    and how far does your doubler hang.
  3. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    My 205 hangs about 4" below the frame, just making sure I really had a 2" clock. (boy am i going to get it for that one /forums/images/graemlins/doah.gif)
    I came up with an awesome way to only have the crossmember hang down about 2.5" with the skid plate, so it looks like i will have to kick down the plate under the 205; which is not a big deal.
    Hey Dan, can you do me one quick favor and measure the distance between the two adapters? It is way too cold to go climbing under my truck right now. /forums/images/graemlins/peace.gif
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Can't find a measuring tape so ill have to get back to you. where do you want me to measure from.
  5. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    between the doubler adapter and the 203 adapter, trying to figure how much space is between them.
  6. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Watson told me it was 3".
    /forums/images/graemlins/thumb.gif
  7. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    is it possible to get the 205 up even with the frame rails? or will this cause drive line issues? /forums/images/graemlins/confused.gif
  8. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    You will have to use like a 4" lift and cut a big hole in the floor, get a high pinion front carrier, have that rotated, then you will need to call Jesse at High Angle Driveline and order a set of bigelow cv shafts.
