how many "amp" for my battery?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by razorblade, Jan 14, 2003.
  1. razorblade
    razorblade Registered Member
    Jan 8, 2003
    6
    italy-monza
    how many \"amp\" for my battery?!
    the battery for my blazer silverado 1981 k5, how many "amp" i need?!?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: how many \"amp\" for my battery?!
    650 Cold Cranking Amps (CCA) is about the minumum. But I prefer batteries with higher CCA's to provide some extra reserve. Somewhere in the 900-1,000 CCA range. /forums/images/graemlins/cool.gif
  3. razorblade
    Jan 8, 2003
    6
    italy-monza
    hi!
    thanks for the answer!
    /forums/images/graemlins/smile.gif
    can i make you a question?
    i have another problem...tha canister of vacuum recycle breathe in some drops of fuel and not only vapour of fuel.
    is there a way to know if the canister has broken??
    thnaks fabio
  4. Grim-Reaper
    7,385
    Atlanta
    All the canister is is a a block of charcoal. My guess would be something wrong with the pumbing. What is supose to happen is it collects the vapors and then the vapors get sucked back into the engine and burned. So if your truck is carb then it's possible that the gas has over flown from the carb or there is a bad check valve.
    Should be a diagram of the hoses stuck to the underside of the hood or on the core suport. It will show the check valves and such as well. once it's working correctly it should clear itself out.
