How many amps do the glow plugs draw?
Discussion in '1982-Present GM Diesel' started by arveetek, Nov 10, 2004.
  1. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    How many amps do the glow plugs draw? I wanted to know for sure, since it has been asked before.
    I don't have an ammeter big enough to read the amp draw for all 8 plugs, so I measured a couple of individual plugs with my hand-held Fluke meter. The result? Two different AC60G plugs pulled 12.75 amps each at startup, slowly tapering off to around 11.5 amps after a few seconds. So, take 12.75 amps times 8 glow plugs, and you get a total amp draw of 102 amps dropping off to 92 amps after a few seconds have passed.
    90-100 amps for 10 seconds or so is a lot of juice, so that's why it's very important to use a separate relay with heavy battery cables to carry the load. Running that much current through a single switch in the cab will probably result in burned up wiring or even in a fire.
    Just thought I'd share! I like to know things for sure, so that's why I decided to check it out myself! /forums/images/graemlins/whistling.gif
    Casey
  2. rd durham
    rd durham Registered Member
    May 20, 2004
    70
    Colorado Springs, Colorado
    100 amp relays can be a little pricey. How about using three or four 40 amp relays and dividing up the glow plug wires accordingly?
  3. arveetek
    Mar 1, 2002
    722
    You can buy a Ford style starter relay pretty cheap, that's the way to go.
    Casey
  4. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    Figure on 15 amps each.
  5. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    GM manual says there should be 55 amps per cyl. bank. 110 amps total, sounds par to me... /forums/images/graemlins/waytogo.gif
    One instructor I had said he would test the individual GP leads with a hi beam headlight...for what its worth...
