How many bolt mounts on my TC should there be? 3?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dasanii19, Nov 26, 2006.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    How many bolt mounts should be on my Torque converter? I count only three, should there be more? Im thinking one or two might have broke off..
    Dont know if this will help but my transmission is a 13 bolt pan, GM turbo 350, my truck is a 1976 k5 blazer..
    By the way, I thought a rod was knocking in my motor!! Took a look at my TC and all the bolts where out except one that could be unscrewed by hand!!
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yep, there is only 3. Well there are 3 on my 400 to 6.2 and there were 3 on my 350 to 350. I had that problem a few years ago too. Sounded like I had some engine problems but turned out to be loose bell housing to engine bolts and the torque converter bolts were loose too.
  3. dasanii19
    Oct 11, 2006
    344
    NV
    Thank you sir :D
    So should I use some lock tite? or just buy new bolts and tighten them back up? Do they need to be torqued at a certain spec?
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Most torque convertors use 3 bolts but some HD convertors use 6 bolts. The fact that the bolts were loose and the convertor was banging back and forth against the holes means your flexplate may be damaged as well. I would inspect the bolt holes for elongation then if it looks good just buy new bolts and re-install them without any locktight but make sure they are tight. There is no torque value for these bolts.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You must have a gas TC.
    The 6.2 diesel TC has 6 bolts.
    I worked on one that had one left of the 6:doah:
    As for the original poster yes 3 on yours and tighten them real good, no locktite so you can take it appart when you need to.
    Like Scott said if you had been running it like this for w hile you want to check the holes.
    What I noticed was that the bolts that fell will have nice clean holes and the one that was left will have a wollowed out hole.
    :eek1:
