How many cans does it take?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Aug 7, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    How many cans of R-134a does it take to recharge the A/C?? I have a 84 Blazer.
    YEEEEE HAWWWWW[​IMG]
  2. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Anybody? I have 3 12oz cans is this enough?
  3. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    Most of the time their will be a sticker on your ac components where on is written how much R134a has to be in system.
    Don`t put in to much it will not work well than, it`s the same if you put to little in it.
    Greetings from Amsterdam,
    River `89 K5, 350, TH700R4, NP241, "33, 2.73, 10 bolt F, 12 Bolt R
  4. rockosangel
    rockosangel 1/2 ton status
    Jul 11, 2000
    277
    Round Rock, TX
    I just took my truck into be serviced and re-charged, they told me any system takes somewhere between 2 to 3 cans. It just depends on the size of vehicle...There should be a sticker on the a/c unit to let you know how much exactly... Just make sure you really need the 134 and it isn't an older unit w/r12 in it. Then you need the whole conversion...which you can get at Pep Boys or any auto parts store. Good luck
    www.rockosangel.coloradok5.com
    www.rocko.coloradok5.com
  5. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    your blazer's a/c system should require 3.12 lb of refrigerant..per the label on the unit.
    This is if it's completely empty.
    for 134A, you need to put a little less in (like 3 lb) as the head pressure on the high side will get rather high when you don't have a lot of airflow over the evap. coil. as 134 has some different properties than R12
  6. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    My 86 says 3.25 lbs of freon, so three cans ought to do you.
