How many D60 front users are running studs or bolts in the u-bolt plate?
Discussion in 'The Garage' started by thatK30guy, Oct 16, 2005.
Which are you running?
  1. Studs
    52 vote(s)
    39.1%
  2. Grade 8 bolts
    77 vote(s)
    57.9%
  3. Grade 5 or less bolts
    4 vote(s)
    3.0%
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    What are you running?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    bolts here, id love studs (comfort factor) but no problems w/ bolts.
  3. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I run grade 8 "all thread" studs. Found a local source for 5/8 NC grade 8 "all thread" and made em myself.
    Rene
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Bolts... good enough for GM, good enough for me. :thumb:
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have bolts, but I just dont trust them.
    I have new studs on the way.
  6. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    Bolts here but I would rather switch out to studs I think.
  7. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I run the grade 8 bolts that came with my original Skyjacker Lift. No problems....yet.
  8. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Studs, I believe they're superlift pieces.
  9. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I run bolts but I am hoping to change it over to a u-bolt soon.
  10. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    My studs are sharring the ride with 85mudblazin's, if I'm not mistaken. So, studs for me, when I throw the 60 in.
  11. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Hey Rene - I have some A36 grade 5/8 all thread, it was actually round bar that we had threaded. Do you think that would be too brittle?
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Sheared both of the studs at different times that came with the Superlift hardware kit. Switched to grade 8 bolts and haven't had any issues since.
  13. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    A36 is plain old mild steel. Certainly wouldn't be brittle, more likely to stretch and break before you get to 100 lbs of torque. On such a critical application i wouldn't risk it. Tensile on mild is pathetic compared to grade 5 and grade 8 bolts. Easily less than half...
    Rene
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I'm running B7 studs and G8 nuts with hardened washers in mine.
  15. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I am running the same setup as Russ.
  16. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'm an idiot, what does B7 mean?
  17. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    bolts for me. and on my second set. i believe the degree shims had alot to do with the first set snapping.
  18. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    gr 8 bolts for me, never had a problem. I wouldn't mind running studs, but bolts are just easier to find. If you change your suspension set up frequently, finding new studs at the correct length (assuming you can't make your own!) can be a PITA. I can drive 5 mins to the hardware place and get bolts of the right length. It would be cool if ARP make some longer-than-stock replacement studs for this application... the steel they use for their hardware pretty much kicks ass.
    j
  19. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    B7 is another spec very similar "G8". It seems that "grade 8" can not be applied to studs or all-thread for whatever reason, so the term B7 is used. I don't remember the details, but it's basically the same as saying "Grade 8 stud".
  20. hotdawg
    hotdawg Newbie
    Sep 21, 2005
    3
    Texas
    I use grade 8 bolts and have not had any trouble at all.
