How many Dana 44 models?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevy409, Apr 13, 2003.
  1. Chevy409
    Chevy409 Registered Member
    Mar 5, 2001
    81
    I just tore apart two GM dana 44 front axles and found different diameter axles...??? Both rear ends have disc brakes, one is from like an '83 blazer and other I do not know of year but it's in a stepside. The axles were the same size where the bearings run but the stepside one was noticabley skinnier throughout the middle of the shaft. Both are six lug axles. What's the secret here, are they just different versions? Also, can I swap the "meaty" ones into the other rearend? pretty sure they were same spline, though I didn not count (doh!). Thanks in advanced. /forums/images/graemlins/usaflag.gif
  2. Chevy409
    Mar 5, 2001
    81
    anyone please...
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    If the one from the "83" is original it is not a D44, it would be a 10 bolt 28 spline axle. The other unknown axle may be a D44 which is 30 spline. If you do have a 10 bolt and a D44 then the inner axles will not interchange but the outers will.
