how many flashers should a 86 pickup have
Discussion in 'The Garage' started by bryguy00b, Mar 19, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my 84 k5 has two flashers..(for the turn signals) ans my 86 only has one...is it suppost to have two? im trying to figure out why my turn signals dont work on it,....
  2. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    There was often 1 flasher for the turn signals & an other for the hazard lights. Not sure which years were which though.
  3. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    if i remember right your '86 should also have 2 flashers on it. one for the turn signals and one for the hazards.
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok thanks guys ill check it out..hopefully thats all it is but i doubt it...well..just havta go see...
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    2, One for Turn Signal's, and one for Hazard's. /forums/images/graemlins/grin.gif
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    so if it was missing the flasher...would they work..and just not blink and stay steady..or would they not work at all?
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Whichever one did not have the flasher, you would get nothing (the circuit stays open).
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok thanx..i sure hope this solves the problem..
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    are they right next to eachother? wear do i see them?
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    one on each side of the fuse panel, there should be a round provision for them. normal to the top of the panel.
    -Jeremy
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok well i found it..repalced it..and it fixed the problem..but it was on another fuse panal...theres like another one next to it kind of that it was on!?...\
    and i have another question..my radio also does not work so of course i went to check the fuse..
    well..the prongs from the fuse were sticking out of it and bent..and they kid of fell/tore out when i pulled them out. and there is like wires sticking out in there..and the plastic around the socket looks melted or beat up or something..and it doesnt look like all the other sockets..with the gold colord inserts for the fuse to easily slide in to..i couldnt even get the fuse in there!! does that mean i need a new fuse panal? what happened!!??
  12. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    any one got any ideas on this?
