How many ft-lbs for front spindle nuts on a Dana 44?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silverado4x4, May 23, 2001.
  1. Silverado4x4
    Silverado4x4 Registered Member
    Oct 2, 2000
    61
    Illinios, southwest of chicago
    i tightened them down to like 25-30, but the axle spindle thing isn't sticking far enough out to put the snap ring on.....
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Actually the axzel has nothing to do with your wheelbearing torque. all you need to do is put a screwdriver behind the steering Ujoint and push the axel out a bit to expose the grove for the sanp ring. Then when you install the outer hub housing you will want to tap it in with a rubber mallet after you put the little allen screws in to make sure the hub is seated all the way in. Don't over torque the littel allen screws[​IMG]
    Hope this helps
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Silverado4x4
    Oct 2, 2000
    61
    oh yea, duh thanks
