How many have a transfer case brace?
Discussion in 'The Garage' started by mrk5, May 30, 2005.
Transfer case brace...
  1. Yes, I have one.
    181 vote(s)
    60.1%
  2. No, I don't have one.
    120 vote(s)
    39.9%
Multiple votes are allowed.
  1. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Just curious how many people have the brace for the transfer case?
    I have a '84 CUCV with the TH400 & NP208 and it doesn't have a brace. I see the threaded holes for it on the transfer case.
    I also had a '75 K5 with TH350 & NP203 and it didn't have one either.
    How common is it?
    and
    How critical is it?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have the factory one for the 83 700/208 combo . The 83 ( different 83 ) 465/208 combo I'm trading had no brace for some reason . My guess is some don't make it back on during servicing , and some just didn't have them to begin with .
  3. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I believe they used a brace to the frame in the early 70's. But if you broke a motormount and the motor twisted up and the frame held the t/c still. Then the alum. ears on the transmission would break, manuels excluded of corse.
    So in the mid 70's they did not use any brace, at least on my 76. By the end of the 70's they began using the brace from the motor to the t/case, so the whole thing flexes as a unit. With the thought of a heavy castiron t/case like the 203 hanging off the back of the alum, th350 with 4 bolts, I would definately go with the brace. With the lighter alum. 208 hanging on with 6 bolts to the th400, then you might chance it if you dont wheel it real hard.
    I've replaced 2 th350's because of breaking those ears with out a brace, so I use one now.
    P.S. Paul, I dont think you need one because the manuel castiron 465 case is so strong and the alum. 208 is so light it dosent need any extra support.
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    That would be a P.S. to me Bob as I'm tryin to get to a point that I can put that 465/208 in Wimpy, but good to know. :)
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've got one on both trucks. I've heard you can crack cases without them.
    Or is that just a story put about by the company that makes them!! j/k :grin:
  6. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    i have it...but when i bought the truck , the bolt that holds the brace to the engine was broken ..took many hours getting the rest of it out..
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I've seen photos here or elsewhere showing cracked bellhousings on auto trannies because of not using them.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    My 75 burb has a TH350/203 and never came with a brace from the factory and still doesn't. Still running the original tcase and original tranny(but rebuilt).
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, you should at least have the braces that go from the motor mounts to the inspection cover/bellhousing. It'll keep you from breaking the bellhousing. TH350s are known for their exceptionally weak bellhousings.
    You should run the support that goes from the bellhousing to the side of the transfer case. It keeps some of the torque off the adapter. I always do on stuff that is stock. On my clocked transfer case I haven't figured out a way to modify a stock one to make it work.
  10. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    The ones I saw were 350/208 combos
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I run them !
    I got the brace and strut bars that go from the bellhousing to the motor mounts on my 700/208 in my 85 K5 and I am using the side torque mount on my 465/203/205 set up.
    IMHO GM recognized the need for these items or they would have never engineered them and paid for the exspense of putting them into production.
    I think they are a fantastic addition wether they came as OEM or not. Anything that helps keep the stresses localized and braces everything up is all good !
    Tom
  12. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    My 79 350/203 combo has one. Have contemplated pulling it off when getting at the bolts to pull the engine but somehow always seems to find itself back on there. I agree with the above statement, if GM found a reason it needed to be on there then I am leaving it.
  13. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Does someone have a picture so I know what I am missing looks like? I guess I'll have to search the junkyards for the brace(s).
  14. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Had one in each of my 74's, with a 350/350/np203 combo. Also have one in my 76 which came with a 350/350/np205.
  15. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I made a custom one for my 350/205 combo...
    Before I made one...I ran the rig hard...without breaking a bellhousing.
    10 years ago...I broke a bellhousing...on my 350/203 combo...
    I was jumping the rig at the time. :grin:
  16. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Both my K30's, '85 and '87, have the back of motor to tc brace and the motor mount to TH400 bellhousing strut rod braces. I have seen people with TH350's crack their cases on non-braced trucks. Haven't seen a braced truck crack it's auto tranny case yet. I would recommend running braces if you can.
  17. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Hmmm, interesting. I had a feeling I was in the minority.
    Well I would like to get a brace on there, whether I make one myself or find a factory version.
    Any chance someone has some pics of the setup on a TH400/NP208? From what I can gather it goes from the transfer case to the bell housing. I guess I'm really curious about how and where it attaches to the bell housing. I'm having a hard time visualizing how it could be very rigid.
  18. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    on my 78 blazer it had the 465/205 set up and there was no place on the transfer case to mount a support. So there for i never ran one. How ever i now have a 75 th350/205 and want one.
  19. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    my 79 with a th350/208 had one, and my 86 with 700/208 had one, hell even my 92 s10 with a t5 has one
  20. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    203 and 205 were to the frames most of the time. and 208 was to the bellhousing with a rod.
