How many leaves for front 56s
Discussion in 'The Garage' started by CyberSniper, Feb 24, 2005.
  1. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    How many leaves are you guys running with front 56s? I was thinking the main, four more, and no overload. The pack originally started with 8 plus overload.
    Which ones do you keep? I was thinking about just getting rid of most of the bottom ones.
    Will that be sufficient for a TBI smallblock and a winch? I'd rather start with too many leaves and remove some than not have enough and add some.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    5 leaves is what is in the 1/2 ton light duty 56" spring packs if I remember right. We installed them in a friends K5 in the back. They are VERY soft and VERY flexy. I would start with 6 leaves (main + 5) and no overload. The 56" springs have way more flex then 52's.
    Harley
  3. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    heres what i did FIRST, i have sence added one leaf from my old 6" bds pack.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Alright, I'll start with 6 leaves and no overload then. I'm running a little less weight on the front than average. Motor moved back 2.5", looks like the cab is going back about 5", and the batteries aren't going to be under the hood.
  5. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I have 4, but I might need to install on more will see
  6. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I ended up using 5 leaves. 6 just seemed to be too many for something light in the front end. Jumping up and down on them they seem to be stiffer than 4" lift 47" springs.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Well, 5 leaves are way too few. They are about 1.5" lift springs now and that's just with a motor/trans/tcase sitting on it. I think I'm going to try 7 leaves. Either that or buy some 4" lift 56" springs.
    As a side note, there is no way in hell a modern tie rod (no split sleeve like the drag link has) will fit under the springs with flat top knuckles.
