How many manual tranny Suburbans...
Discussion in '1936-Present Suburban' started by mountainexplorer, Dec 28, 2003.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I can't remember if this has been asked before... so if it has, forgive me. But I was wondering how many of you out there have Suburbans with SM465s (or manual trannys of some form)? And if you do, was it factory, or a conversion?
    Also, how many Suburbans do we have on here with Dana 60 fronts?
    Mine is an '81... used to have a 350, TH400/NP208, 10 Bolt/14 Bolt SF, and 9.50R16.5 tires. Now... 5 years later, it has a 454, SM465/205, Dana 60/14 Bolt FF, and is on 35's.
    How did yours start out and where are you now?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Same in 1975 as in 2003 /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
    Same shitty diff ratio also /forums/images/graemlins/rotfl.gif
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my parts burb was abone stock 78 3/4 ton with 305 sm465 with 3.73's.
    my current burb is 6.2 th400 and is getting the above axles as we speak.
  4. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Well mine started with a 350/TH350/NP203/4.10 Dana 44/12bolt.
    Here is what I am now, Rebuilt 350/New TH350/Different 203. 4.10 Dana 44/3.73 14 bolt.
    Working on the dana 60 right now.
    Goal is 383/700r4/ORD Doubler/Dana60/14 Bolt w/5.13s
    And I got the 42'' TSLs sitting here waiting for the gears and axles to be finished.
  5. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    My 90 came bone stock with a tbi350,sm465,np241,10b front3.73,14sf rear 3.73. It now has a carbed 454,sm465,np241,dana60 5.13.dl,14ff 5.13.dl & 39.5 tsl.
  6. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    Mine is a 1973 k20 suburban... Came stock with a 350/th350/np203. Someone swapped in a 205 at somepoint, and a high reving high horsepower engine with no lowend torque. Come mid january, it'll have a 454 between the fenders. Axles are d44 front, 14bff rear, 4.10's. Plan on replacing the broken d44 with a d60.
    -rich
  7. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    78 1/2 ton Stock:350/465/205
    Now BBC 396-30 over /th400/np205 For sale
  8. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Mine came with 350EFI + sm465 + np241 + 10bolts
    I have replaced the 1/2 ton axles with 1ton axles. /forums/images/graemlins/burb.gif
  9. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    mountainexplorer how much lift is under your suburban
  10. mountainexplorer
    Nov 14, 2001
    4,903
    Mine has a 6" suspension lift; 4" rear blocks with 2" add-a-leafs and sagging 6" front springs with a homemade 1" zero-rate.
  11. one ton burb
    Nov 15, 2003
    119
    Ontario, Canada
    thanks man oh by the way I like your fleet of trucks someday I would like to have the room to have that much trucks
  12. mountainexplorer
    Nov 14, 2001
    4,903
    I'm lucky to have the room... though someday I'd like to get rid of the "wrecking yard" look from our property, and just keep the fleet around with only a few parts rigs instead of a field full.
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Try the brochures at http://brochures.slosh.com/
    I see 4-spd manual trans availability in the Burb up to 89 (Aug 88). Looks like with 305/350/400/454 for 73-78 and 305/350 only for 79-89.
    As rare as they are, the only 4-spd Burbs I've seen are 70's 4wd versions... all with smallblocks.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I had a 1975 2wd C20 with a 454/4-spd
  15. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    retired forest service burb at work has sm465.
