How many of you have a black residue on your tranny dip stick?
Discussion in 'The Garage' started by MilpitasK5, Jul 24, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    How bad is that? It seems to be shifting normal but my fluid smells burnt but is still red too. I just changed the fluid and filter about 4 months ago.
    I just installed a B&M Tranny cooler to keep the 700R4 cool.
    Do I have to worry about it taking a crap on my out of the blue or will there be signs? /forums/images/graemlins/confused.gif Can I still go on long drives? /forums/images/graemlins/thinking.gif
    TIA
  2. Grim-Reaper
    7,385
    Atlanta
    Sounds like your talking about Varnish....Proably normal to some extent. All the dipstics on my burb have it and my Burb only has 74k on it. on the oil dip stick you can tell when it passes by the exhaust manifolds. It's much darker.
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Okay, that sets me at ease a little more /forums/images/graemlins/thumb.gif.
    Thanks for the input Grim!
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    are you talking about the black "powder" looking stuff on the bottom of you pan when you dropped it?
  5. Grim-Reaper
    7,385
    Atlanta
    I'm at work and I got side tracked and forgot to comment on the burnt smell.
    When you drop the pan you only get about 6 pints of the fluid changed. You still smell the burnt because there is still some burnt fluid running around in there.
    That tranny holds probably 16 pints. There is not a way to drain the converter. A oilchange place may have a machine that ties into the cooler lines. Those will change about 80-85% of the fluid. I'll be having this type of change done on mine in the burb in the next week or two.
  6. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I think it's that same stuff.
  7. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I see, so I'll need to take it to a shop then? Hopefully I can find a good one. I'll check w/ my mechanic though first. Hopefully he has all the nees at home! /forums/images/graemlins/thumb.gif
    Anything else I need to look out for or do?
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Why only 80% with a flush? The only fluid I can see not getting changed is stuff in the valve body, accumulators or servos that does not move during the flush. It does of course flush the torque converter since that it part of the normal flow of fluid through the transmission.
    A 700R-4 with stock pan and stock cooler holds almost 3 gallons
  9. Grim-Reaper
    7,385
    Atlanta
    Because it would take 20 quarts or more to get anymore of the old fluid out of the torque converter....The torque converter is just a big container. Fluid pumps in and mixes and then some comes back out and drains back into the pan.
    It's just cost prohibitive to try to get any more then that.
  10. Blue85
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Yeah, I guess I see what you're saying.
    I've done the flush at home a few times. It's real easy if you have an auxilliary tranny cooler. Just disconnect the return line rubber hose and stick it in a jug. Run the engine in short increments. Look at how much is in your jug and add that much new fluid down the fill tube. This is actually easier and less messy than dropping the pan. /forums/images/graemlins/thumb.gif
