How many of you have a NP205
Discussion in 'The Garage' started by blueblaze, Aug 10, 2004.
  1. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    Just wondering how many of you guy's run a NP205 Chevy.
    Also what have you done to it, twin stick etc...
    /forums/images/graemlins/ears.gif
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I have a stock 205 in my crew cab. In my K5 I'll be using a 205 with a 32 spline input, a 32 spline front output, 1350 front yoke and a 1410 rear yoke. The K5 is also getting a Doubler.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I have a 205 I think it is a great add on to a 203 thank you ORD /forums/images/graemlins/thumb.gif /forums/images/graemlins/woot.gif
  4. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I am running one. It's stock.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    stock 1978 np205 and a JKW twin stick kit.
  6. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    On JKW website it say's the 205 need's to be a ford 205?
    Can you still use it on a chevy 205?
  7. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I'm running one, it's stock.
  8. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i got one, but its not in the truck yet
  9. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Stock 205 here also
    JKW website has a listing for both the ford and chevy model
  10. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    That's the info I'm looking for...any one else?
  11. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    What did I win? /forums/images/graemlins/grin.gif
  12. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    Stock 205 here also
    My bad, I can see the light now... /forums/images/graemlins/doah.gif
  13. blueblaze
    Dec 4, 2001
    274
    Salt Lake City, UT
    [/ QUOTE ] /forums/images/graemlins/ignore.gif
    /forums/images/graemlins/waytogo.gif
  14. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I forgot to mention that I have single stick shifters on both trucks.
  15. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I am running a 205 . I pulled the TH700R4/NP208 out of my Blazer and I am putting in a 465/203/205 combo.
    I am using an older ( 1973 model ) 205 behind my Doubler but I have upgraded to a 32 spline front Ford output shaft and have 1350 & 1410 yokes front and rear ( all depends on what drive shafts I will use ) . I have been thinking about using my 1983 model 205 with the newer style shift rails and 30 spline front output shaft though - I like the almost "no-slop" feel of the later style shift forks/rails .
    Tom
  16. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i got one, not in the k5 yet. i need the bolts that connects the lever to the adapter and this seems like a good forum tho ask if anyone knows the size of that bolt??
  17. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have one, and a 203 for a doubler. but nothings on the k5.
  18. Jeromy Gibson
    Jeromy Gibson 1/2 ton status
    Apr 17, 2003
    127
    Amarillo Texas
    I will take a stab at it. I have the 465/ 205 combo in the truck and two extra tranys and tcases sitting in my shop, just incase I break one. All stock untill funds allow more.
  19. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I have the original unmolested NP205 in my Burb....with the original shifter. /forums/images/graemlins/waytogo.gif
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    GM NP205 case with Ford internals including 31 spline input and 32 spline front output running 1410 yokes. The case was enlarged for the large bearing input (just like GM 32 spline but with 31 splines) and twin sticked mounted behind a 203 range box. Shifter is a home-fabed custom transfer bar design similar to ORDs twin stick shifter but mounted to the end mount tapped holes.
