How many of you have rebuilt an engine?
Discussion in 'The Garage' started by colbystephens, Feb 13, 2006.
Have you rebuilt an engine?
  1. yes
    150 vote(s)
    60.7%
  2. no
    32 vote(s)
    13.0%
  3. yes and i do it nekkid
    48 vote(s)
    19.4%
  4. no, but i'm nekkid and that's all that matters.
    17 vote(s)
    6.9%
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    just curious how many out there have done a full overhaul on their engines. feel free to post up as "yes" if you are in the middle of your first build - like myself. ;)
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    i got the 4 bolt main 350 out of a suburban i overheated pretty bad and swapped it in my blazer, building the motor was really fun, swapping it in is kind of a pita. it was going through my head recently to rebuild a diesel for a tow rig i wanna make
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Back when I was in high school, many many years ago, I rebuilt a 289 Ford with much guidance from a retired heavy equipment mechanic. Nothing hi-po, just a basic rebuild.
  4. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    I have, but not the engine in my truck, or any car for that matter. Back in high school I built a 1940 Farmall Model H 4 cylinder. Resleeved it with a 1/8" over-bore, shaved the head, and installed a set of 1" dome pistons in place of the flat tops. Used to have to start out in first and work your way up through the gears regardless, now you can start out in 5th, on a hill, pulling something :D. I've had a 350 apart, but not rebuilding, just going through replacing seals and gaskets.
  5. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    i did I re did a 305 I got for nothing for it to not fit bc of the rear seal , and a few years ago i Had an 88 F150 with a 5.0 , and threw a rod threw the cam , bought a bone yard motor rebuilt it and threw it in . I have seen it on the road a few times now
  6. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i also rebuilt a 302 ford motor out of an 86 bronco that i used to own that i got in trouble withs so i donated it to the school
  7. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Couple of Small Block chevys, couple of four cylinder gassers. A whole bunch of Detroit series 50 and 60 diesels, partial rebuilds on some caterpillars and two cycle detroit diesels and a continental four cylinder diesel.
    My dad owns quite a few Perkins diesels but they just dont ever tear up or wear out, so Ill probably never rebuild one of them.
  8. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    doing my first complete tear down and build. I'm working on the 454 that's going to go in my project blazer. I'm going up from a bare block. I'd be totally lost if it weren't for my dad. He's helping alot along the way, pointing out things I should do or shouldn't do ect...
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    6 Chevy 350's
    1 Chevy 388
    2 Pontiac 400's
    1 Pontiac 389
    1 GM 2.3L Quad4
    :D :D
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yes, this is what i do for a living. I've rebuilt just about anything that runs on gas. The earliest i've done was a 1911 EMF but have done many model A's and flatty fords along with your common SBC/BBC and the other makes of common engines such as Ford and Dodge and a handful of import stuff too.
  11. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    A stock 350, a 450 HP 383, a 383 short block I completed, and soon will rebuiild a Mustang H.O. 5.0
    Its not that difficult, just make sure you have all the tools needed and take your time, double check and assembly lube is your friend!! :waytogo:
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    well, i'm in the middle of reassembling my 6.2 after i had tons of stuff done to it at the machine shop. this is the first engine i've rebuilt. i'm really surprised at how easy it is to do. i think the hardest part of all of it is keeping everything perfectly clean. i think i've done a good job at that - but it's kind of a pain to have to be so meticulous. :) oh well. comes with the trade.
  13. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Did bikes and cars, engines and clutch trannies. Autos seemed like voodoo, but I realized if I'm gonna do traps, I've gotta either buy or build. So I bought the book and built a TH350. Its in my Burb today. Here's something interesting for the Engr. students, especially good for you Colby. As you go through your 6.2, are you reverse Engr. the hows and whys? Given that, realize it was Engr'd from technology 100 yrs. old. Fast forward, I would recommend going out of the way to study the guts of a TH, probably any of them, and study the processes; you should be able to see the difference 50 yrs makes. Its amazing. If I were teaching Engr., I could spend a year just on all the history, processes, disciplines etc.:bow:
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    never done a whole motor yet. farthest ive gone is rebuilt heads on an old 340 buick i used to have. done the top end on a 2stroke dirtbike a couple times, but those are easy. planning to do my first complete rebuild on a 4bolt 350 i have laying around, just gotta stop putting other projects in front of it and start saving for parts.
  15. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    LOts and lots of rebuilds from mild to wild, from gas to alcohol injection.
    I currently do alot of heavy truck and equipment in-frames.. I love them Cat and Cummins, there big and heavy but you have alot of room to work on them..
  16. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    1,chevy 283
    1,chevy 350
    1,pontiac 428
    half a chevy 305
    and lookin to do another 350 for the blazer
  17. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I have tightened up a valve cover bolt,,,,,does that count???:doah: :D :D
  18. LVJimmy
    LVJimmy 1/2 ton status
    Aug 22, 2005
    301
    Lost Wages, NV
    Chrysler 383, Olds 455, Chevy 350 and in the process of doing the 350 again.
  19. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    I rebuilt my first engine at 19 by myself after reading a few books on the subject and the engine was still running 252,000 miles later when I pulled it to put in another engine I had rebuilt. I had no idea what I was doing on the first one and I don't know how it lasted that long. I think the trick was that I put in really high end bearings and rings. But I really learned a lot and really enjoyed it. Smallblock chevy's rule. You gotta love the mouse.
  20. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's what i'm shooting for. this is my first engine - i'm 20 and i don't have any instruction. it's amazing how much you learn just by doing this. i'm shooting for a few more than 250 thousand tho. :D We'll see.
    :bow:
