how many of you have run different gears front and rear?
Discussion in 'The Garage' started by monster man, Oct 18, 2005.
  1. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    I just got a 14bff open carrier with 4.56 gears to replace my Gov-Loc 3.73 carrier. Will throw a Detroit in and all will be well- except for the front. My plan is just to run in real two wheel drive until I get stuck- at which point I'll engage the front 3.73 gears to unstick me, and then go back to 2wd. How feasible is this? It will be a pain, I'm sure, but I won't have the spare funds for the front for another month or so, and by then I could have a line on a 4.56 Dana 60 front, who knows. What do you think, am I asking for trouble? I figure if it's stuck enough to need four wheel than it won't bind my t-case up. :confused:
  2. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    I'm not so sure about doing that. I supose that if you aren't going to be on any paved surfaces... basicly anything but slick mud. If you want to do some fourwheeling on lots of different surfaces I would not recomend running different gears. I would say just sit on the 14bff... maybe clean it up make it look pretty until you can afford the D60 with the matching set of gears.
    You can maybe get away with it but I would just hold on to what I got until things match up. :o
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I think you would just be asking for trouble. Unhook that front d-shaft and save for gears.
  4. monster man
    Oct 20, 2003
    282
    Reno, NV
    the 14b is in the truck now, and I really need the gears after the tire swap, so I bought the open carrier with 4.56's to kill two birds with one stone- acceleration and real traction. I guess the good news is 4.56 carriers for a D44 are cheaper......
    EDIT...... or.... can I use a set of thick gears for the front D44, or is that only an option on the 14b?
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    If your not planning on using it regularily it should be fine. Some of the hardcore mud guys run higher gears in the front for more wheel speed up front. All that will happen is your front tires will spin faster. If its just to pull you out of somewhere you got stuck go for it.
  6. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    you can break lots of spendy pats doing that even in mud.also will be hard to control with tires spinning at dif speeds.
  7. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    you could run 34's in the front and 42's in the rear... but i still wouldnt try it on-road
  8. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Thats what I did--temporarily!!
    I bought a 71 K5 for 300 bucks years ago--found out why it was so cheap the first time I locked he hubs and used 4wd!..it had a 3.08 ratio rear axle,and a 3.73 front!(evidently someone blew the rear end,and tossed in any old 2wd truck one they could find to sell it!)..it binded up so bad the frame flexed,and one hub went "POW"..it slipped out of engagement due to the bind.. :doah: (this was on my tar driveway--in sand or snow,it might not have been so apparent..)
    I put 33" tires on the front,and left the stock 235/15's on the back--I was then able to use 4wd without it feeling like I was going to split the transfer case in two..
    I located another rear axle with 3.73's,but I ended up selling the truck before installing it--I gave the new owner the other rear end--but he never installed it either!--,he said it worked good enough for him the way it was--and he was moving to Texas anyway,where you rarely need 4wd on the street!
    His dad called me one day,about 2 years later!--
    asked me if I wanted the axle back!
    so I took it,ended up selling it to another guy who needed it... :crazy:
  9. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    4.10's in front 4.11's in the rear no problems so far. miller locked rear and trutrac front.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That don't count , 4.10 and 4.11 , thats within tolerance :D
    Tj ran 3.42 fronts and 3.73 rears before when he got the 14bff , and still had the 6 lug front . He ran two tire sizes so it was close enough for dirt when we went fishing and camping .
    Hit hard pack , and it bind a little .
  11. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    YUP, it'll bind as soon as it gets traction,,,big time,,,
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    On my '90 I currently have 4.10's in the rear and 3.73's up front. But I haven't put it in 4WD. :eek1: I've got 4.56's for both ends, just have to get time to install 'em. :cool1:
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If you run it in 2wd there should be no issues with having different gears in the front axle. Along those lines, if you get stuck in 2wd there should also be no issue with engaging 4wd to get unstuck.........if there is so little traction that you are stuck there is absolutely no reason you could put enough force into the drivetrain to cause binding and breakage with the different gears.
    With that said, I would only use 4wd in an emergency stuck.......simply because I would recommend keeping away from any trails or other places that you will probably need 4wd until you get it fixed right (ie..matching gears in the front).
  14. monster man
    Oct 20, 2003
    282
    Reno, NV
    that was pretty much my line of thinking- the tricky part will be engaging it just long enough to get unstuck but not a second longer :D
    Maybe now's a good time to fab up a twin stick as well to use 2 Low.......
    Then again I think regearing the front would cost less :rolleyes:
  15. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I personally wouldn't risk it. 1 mistake and kapow!
  16. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Thats basically what i did for awhile, but with 3.42 in the front, and 3.73 in the rear,,they are very close anyways, and then to top it off, i had smaller tires in the front as well,
    I would use it ONLY when needed, get unstuck, then back to 2wd, but if i were to keep going with it, like try to drive down a hard packed dirt road, it would try to bind up on me.
    Not recommended, but can be done, just be careful with it, and do not hammer on the throttle also listen for any odd noises, if ya hear them, get it out of 4wd asap.
  17. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    A little off topic but im almost positive you need a new carrier to run that detriot. i dont think it works w/ the gov lock carrier, or am i just a little off base...?
  18. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Uhh, that Detroit should be a full replacement. He didn't say "lunchbox locker"
  19. 79k20350
    Nov 22, 2004
    7,757
    Ct
    dude a detriot for a 14 bolt ff is a lunchbox locker
  20. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    lmao... that was awesome...
