How many quarts does the 208 hold?
Discussion in 'The Garage' started by Esteban86K5, Apr 1, 2004.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I've looked and can't find it anywhere. I know that your supposd to fill it till it comes out the fill hole, but mine is clocked and that just doesn't work anymore.
    Thanks /forums/images/graemlins/thumb.gif
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    As many as it takes for it to start coming out of the fill hole. similar to the diffs.
  3. Esteban86K5
    3,712
    Bakersfield, CA
    Did you read my original post? /forums/images/graemlins/doah.gif My T-case is clocked up so now my fill hole is ALOT higher than it was before. So if I were to frill it to the fill hole I would probably blow some seals because of so much fluid. /forums/images/graemlins/tongue.gif
  4. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Actually, if i am thinking right, even if you clocked it up, you are actually filling it with less fluid now, the drain hole is towards the bottom, fill towards the top. Or am i mising something else here, i could have swore they were almost identical to the 241 case.
  5. Esteban86K5
    3,712
    Bakersfield, CA
    The FILL hole is on top, you are correct. When the t-case is in the normal postion, and i fill it up to the fill hole then i would be filling the t-case to about half. Now that I have it clocked up. the fill hole is higher and if I fill it to the fill hole then I would be filling the t-case about 3/4 of the way. Which would be too much.
    BTW I am guessing on the 1/2 and 3/4. just useing those as easy reference. /forums/images/graemlins/smirk.gif
  6. 4xcrazy
    Oct 31, 2003
    9,471
    5
    OK i think i understand what you are saying now, my bad, if i remember correctly, i believe i had to put in about 4 qts to fill mine, maybe 5, the other thing is i do not believe you will blow ant seals out due to the vent tube on the top of the t-case, unless you have done something elst with that as well, pressures won't build up. Hell when i got mine back together, i didn't get around ti installing the hose back on right away untill i notice it was blowing fluid out of it and all over the place.
    I would probably do about 4 qts.
  7. Esteban86K5
    3,712
    Bakersfield, CA
    4 quarts got it. /forums/images/graemlins/waytogo.gif Any one else?
  8. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I'm living dangerously and filled mine up till it ran out on my 241. So far, so good. It took 5 qts to fill it up this time. I've been running it for a few weeks now and "knock on wood" NO problems.
    KP
  9. Esteban86K5
    3,712
    Bakersfield, CA
    I was hoping you'd chime in seeing as your the only one running this set up right now. Well i guess i'll dothat too. I don't do a lot of highway miles on it anymore so I shouldn't have problems either.
    BTW, do you have any more progress pics on that crossmember?
  10. Kyle89K5
    2,273
    OKLAHOMA
    Mine see's about 50-60 highway miles a day running out at ~70mph. Seems to be doing alright.
    On the crossmember, none yet. Doesn't seem to be enough hours in the day with a 3 month old baby at the house. I've got all day saturday blocked off to do some work though /forums/images/graemlins/grin.gif
  11. Esteban86K5
    3,712
    Bakersfield, CA
    Try haveing a 6 year old 4 year old and 1.5 year old. I HAVE to shave my head or head I'd be pulling it out. /forums/images/graemlins/doah.gif
    I sneak in a couple of hours here and there to work on mine. I also do some late nights afer everyone is in bed. /forums/images/graemlins/grin.gif
  12. Kyle89K5
    2,273
    OKLAHOMA
    OUCH!!! /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
    I'd pull late nights EVERY night, except for one little problem. My wife and son sleep n the other side of the shop wall /forums/images/graemlins/frown.gif They can hear me when I open a can of Pepsi. I ahve to go to bed when they do... Just another reason I'm looking for another house...
    I'll post more pics as I get stuff done. Got a new shock project coming up that might be kinda interesting...
  13. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Nine pints... so buy a gallon and a quart.
  14. Esteban86K5
    3,712
    Bakersfield, CA
    So 4.5 quarts. COOL!! /forums/images/graemlins/waytogo.gif
