How Many Quarts of Gear Oil...*(UPDATE)*
Discussion in 'The Garage' started by 1-ton, Aug 17, 2004.
  1. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    go into an NP205.
    I want to change the oil in my NP205. My cheap ass Haynes repair manual does not even come with this basic information.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: How Many Quarts of Gear Oil...
    I'd say about 4
  3. JonV
    JonV Registered Member
    Mar 17, 2003
    27
    Hesperia, CA
    Conventional transfer case holds 2.5 U.S. QTS, fill to plug hole. Use 80W-90, GL-5. In Canada, you can use 80W. I live where its HOT, so I use a 90W /forums/images/graemlins/cool.gif. If you have a PTO, may take more.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I used about four by the time I got done making a mess.
  5. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    Thanks for the replies. I am going to get a couple more quarts of gear oil to make sure I have enough.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I use 85W-140.
  7. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    That is what I got. I bought some of that cheap Wal-mart Super Tech SAE 85W-140 GEL-5 that goes for about $1.75 a quart.
  8. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    Re: How Many Quarts of Gear Oil... *(UPDATE)*
    Well, JonV was correct. My transfer case took 2.5 quarts to fill. It was definitly automatic tranny fluid that came out of it, but I put 85W - 140 GEL-5 back into it.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yours is so new it's probably spec'ed for ATF, but I would put GL-5 in it also if I were you.
  10. 1-ton
    Apr 17, 2004
    2,882
    160
    Las Vegas, Nevada
    The transfer case is a little quieter with the gear oil instead of the ATF (not that it was all that loud to begin with).
  11. jon v
    jon v Registered Member
    Jul 8, 2004
    22
    Hesperia, CA, USA
    General rule of thumb. Newer chain driven transfer cases take lighter oils like ATF. My 1979 owners manual says for full time 4x4 10w-30 or 10w-40 engine oil and only fill to 1/2 inch below filler plug hole, and it holds 4 qts. Conventional gear driven, NP205, gear oil... OEM spec GL5 80w or 80W-90, fill to level of filler plug hole. You'll do ok in vegas with 85w-140, cause its so hot, but what happens in manual transmissions is the syncros don't like to line up with heavier oil, especially when its cold, and it's harder to shift. You don't want to be too heavy viscosity in tranny or transfer case. Axles go heavier, 85w-140 or 90w, or 140w. Cold ambient air temps, no, 80w-90 or 90w. /forums/images/graemlins/cool.gif
