How many quarts of oil ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Apr 23, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Time for oil change, forgot how many quarts the 305 takes... anyone know? Thanks.
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I believe all small blocks take 5 all big blocks six.
    I usually use 4 and a qt of Marvel Mystery Oil...its so old and known they used to use MMO in chariots!
    I usually buy 5 anyway so that I can have a bottle on hand to refill if needed. I check every fill up.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    When I change the oil in my 350 (with filter change) I usually use 5-6 quarts. Interesting enough, during spring break I changed the oil in my truck, then my dads F350 (460 V-8) and it took less oil then my 350 did. I just thought that was weird being a big block. I really don't care though, because that truck never hardly get off the cold make (engine temp) unless it is summer. (in AZ).
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Assuming you still have the stock oil pan on your motor, it should take 5 quarts. I always use the longer oil filter on my motors & they always held 5 quarts.
