How many RPM`s do you turn
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JMZ, Jul 11, 2002.
  1. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    Just curious. My friends have been telling me I need a tach, because I would be scared if I knew how many rpm`s I was running. Well I put one in and had it to 6k. July the fourth night at a party before I had the tach I would guess it was about 1k higher.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    some people do run that high i would not do it on a regular basis i have never taken mine over 5000 i rairly go above 4500 my sbc350 starts loosing power at around 4000 and over so no need to go above
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i try not to go over 5k. and 3k tops cruising...
    ARQ.
  4. ryanNC
    ryanNC 1/2 ton status
    Dec 7, 2000
    182
    North Carolina, Valdese
    i've got a balanced and forged bottom end with soild lifters on the cam with a 406 and turned it 7800! before i got a crane ignition box with the limiter set at 6000 now. sometimes you got to give it hell to push through 4 1/2 feet of vegitated mud in front of all your buddies sometimes right /forums/images/icons/grin.gif i'm glad i paid all that money for my racecar buddie to come over and help me do the little things that keep a motor together. spent 5k all together on parts and labor ouch! its costed me alot more breakage down the road and made me spend more more money on other top quality parts to keep everything toghether.
  5. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    On the highway I'm spinning about 3000 @ 60mph. I've gotten to 5500 climbing a sand dune but try to never get that high on a regular basis. I've got a quadrajet, edlebrock intake, fairly stock 350 and dual exhaust without h pipe and flowmasters.
  6. blazingjesse
    blazingjesse 1/2 ton status
    Mar 13, 2001
    159
    kayenta, AZ
    I'm turning 3000 rpm at 75mph 3:73 gears and 33 inch tires
    perfect combo for street sand and mud.oh and getting 12 mpg.
  7. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    I had the 502 upto 5000, but max rpm is 5800. I run at about 2300 cruising at 55, 4.56 gears w/ 39" boggers. Uh, gas mileage?..........7-8 with the wind at my back going downhill.
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I turn 3000 rpm at 60mph with TH350, NP205, 3.73 gears and 32" tires.
  9. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    I run 2700 RPM at 65 with 3.73's, 33's and 1:1 top gear in my 3-speed.
  10. Kev71
    Kev71 Registered Member
    May 6, 2002
    45
    Roswell, Georgia
    At my average cruisin speed of around 45 mph, i run about only 2k and 2500 on the highway at about 60 with 33s.
