How many threds are safe?
Discussion in 'The Garage' started by Brians89K5, Oct 23, 2006.
  1. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    I am in the process of installing 1/4 inch spacers on the front of my truck so I can gain some tie rod clearance. I have good clearance now but it seems that the lug stud doesn't have enough thred. I can get about 3.5 to 4 turns with the lug nut when they are hand tight.... Think its enough to be safe or should I figure something else out? I am running 16.5 inch rims so I have been having problems with backspacing from the get go. Thanks!
    ~Brian
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I wouldn't trust it . I would want at least most of the lug nut taken up with lug threads , like the factory closed end nuts .
    If you were drag racing , they would want the lug nut diameter sticking out open end lug nuts . That says what you need to know about safety and the threads .
  3. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    OK thats what I was figuring. Thanks for the re-inforcement. How much meat is on those tie rods so I can clearance it away from the rim? THanks again!
    ~Brian
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    how much do you need?id go get some new studs, run the spacers.
  5. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    It turned out I didn't need that much more clearance. I took my grinder to my tie rod and now everything is good to go. Thanks for the help though!
    ~Brian
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    FWIW one bolt or stud diameter worth of thread engagment is usually considered the minimum.
    Not sure why NHRA has that stick-thru requirement, but that usually results in more thread engagement than is absolutely necessary. Not a bad thing in this case, but might not always be possible.
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    So he could just get some REALLY small diameter wheel studs then??? :D
  8. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    haha no thank you! I had dreams of loosing my rim and tire going down the road... then I realized it was a nightmare and I decided I'd rather have too much thred than not enough.
    ~Brian
  9. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I was thinking in terms of 10-32's.
    About 1,200 of them!
