How much ATF in 700r4 and 208??
Discussion in 'The Garage' started by 85mudblazin, Jan 15, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I need to change out my fluid, so how much does my 700r4 tranny and 208 hold??
    -Chris
  2. Sidepipes
    Sidepipes 1/2 ton status
    Nov 9, 2002
    139
    St. Thomas, Ontario, Canada
    I used a case(12 quarts) when I put my rebuilt tranny in ( 700/241) in my truck. the tranny had been put on a dyno so there was probably already some ATF in the torque convertor.
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    fluid info
    12-14 quarts and tcase about 1-2 quarts atf tranny depends on pan and converter size.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I plan on just dropping the tranny pan and I am taking my t-case out to seal it back up so there will prolly be some still in there, ill just get 4 gallons of it.\
    Thanks yall :)
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    to do a filter on a 700r4 takes 5-6 quarts, and the np208 takes 4-5 quarts.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    How do you change out the tranny filter?? Just like a oil filter?? Do they look the same??
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    drop the pan on the tranny and its right there, a big plastic thing. it just slides out, then you need to get the seal out of the pump with a screw driver or something. just don't damage the pump. then just slide a new filter up in there with the seal on the filter.
    i would replace the filter if you are changing the fluid. if it gets cloged, it can't pump any fluid and its not moving. it may even burn it up because not enough pressure to the clutches and lets them slip.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    cool thanks, so can I get a filter from any auto parts store??
  9. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Be aware , there is a little "O" ring on the filter that may stay in the tranny when you pull the filter out
    Make sure its on the old filter or you will find the trans. does not work properly
    (screwy shifting etc.) after you put in the new one (doubled up "O" rings)
    This advice was given to me by a guy that works at a trans. shop:thumb:
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    any auto parts store will have one.
    the reason the screwy shifting happens is because when the pan is tightened up it cracks the filter and it sucks air instead of fluid, so make sure you take the filter seal out of the pump.
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok ill make sure I get it out.
    Thanks yall :)
  12. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Listen to big83chevy4x4... that is the rated fluid capacity in the manual
  13. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Be advised that ATF comes out of the drain hole of a 208 MUCH faster and with MUCH more force than motor oil out of the oil pan drain during a regular oil change.
    Make damn sure your drain pan is far enough back from the transfer case and that your face is WELL AWAY from the work area when you spin out the plug.
    Ask me how I know.........:deal: :doah:
  14. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yea I have already experienced that, lol I had the drain pan to close and when I took out the plug the fluid missed the pan by about 1 ft, talk about alot of fluid :)
    ill be more careful this time :)
