How much ATF in clocked 208?
Discussion in 'The Garage' started by DougK20, Mar 8, 2005.
  1. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Just clocked my 208 to full rotation. Curious now how much ATF to put in. It was bone dry. I have added 7 quarts so far.... How much more?????
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Wow 7? its like 3 for normal isent it?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you should only put what is recomended for it. the fluid will expand when it gets hot and with 7 quarts in it, it will go out the over flow on flat ground.
    i put 4 in mine and never had a problem. i wouldn't go any more than 5.
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I filled mine untill it came out of the filler hole like you would in the stock position. Never have had a problem with it. Doesn't come out of the filler either.
