How much backspacing do you use?
Discussion in 'The Garage' started by 84gmcjimmy, Mar 10, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Hey, I was wondering how much backspacing you have on your rims, and the tire width/rim width you have with it. Thanks!
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    2.75" backspacing
    33x12.5x15" BFG AT's
    15x8" steel wheels, 8 lug (had the same tires on 15x10" A.R. Outlaw II's with 4" backspacing when I had my 1/2 ton axles)
    Pics of both setups in the link in my signature.
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I just ordered a set of 15x10 8 lugs for my 38.5x14.5 TSL/SX's, they are 4.25 backspacing, so going to have to grind my D60 calipers /forums/images/graemlins/hack.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    4.25 inch backspacing on 15x10 wheels with 35x12.50 BFG Mud-Terrains mounted on them here. I like the way it keeps the tires tucked under the fenders. /forums/images/graemlins/cool.gif But as you get into larger tires then less backspacing can help keep the inside of the front tires away from the frame when turning.
  5. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    15x8 8 luggers with 4" backspace....38.5/14.50/15 SXs....3/4 ton brakes on my front 60= minimal grinding... /forums/images/graemlins/thumb.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    38.5x16x15 TSL
    15x10 wheels 4.25" Backspacing
    D60 front
    REAL D60 brakes on my D60, so four hours last weekend grinding each side (good thing a fellow CK5er showed up to help out and we both finished at about the same time).
    Fitting 15" rims so you can have a safety bead, AND running enough BS to keep the maximum amount of tire tucked under the fenders.....
    Priceless! /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  7. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'm using US Wheel Model 70's (white spoke 8-lug) in the 15 X 10 size with 4.25" BS. I have 35 X 12.5 X 15 Goodyear MT/R's mounted to them. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
  8. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I have 40's on 4.25 15X10. I have the axle forward 1.5" and I had to cut /forums/images/graemlins/hack.gif the core support to clear. O yeah and grind the crap out of the calipers.
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    2.75" backspacing on 15x10's with 35"s on my D60. required very little caliper grinding. /forums/images/graemlins/thumb.gif
  10. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Ryan,
    How much do you tires stick out from under you fenders? Got any pics looking down the side to get an idea...
    I am still trying to figure out the optimal BS on my truck with a D60 and 15x10's
    Chris
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    15X10 8 lug rims with 3.5" back spacing. 36X14.50X15 Ground Hawg 2's
  12. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    15x8 with 12.5 x 38TSL's about to be 42's. Front backspacing is 3.5" rear is 2" My track width is equal without having to run spacers, but if you drive on the street then you can't rotate your tires either.
  13. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Hey leadfoot, Have you moved your axle forward at all? Do the tires hit your springs at full lock? Just curious, my sx's are on the way here right now. I'm running identical front as you, with the exception of 10" wide rims. Thanks.
  14. leadfoot067
    May 14, 2001
    1,563
    my axle is 1" forward and my tires i havent installed yet...but my 36SXs didnt rub nor were they close...
  15. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    33x12.50s on 15x10s with 4" of backspacing. You can get away with as much as 4.25" of backspacing with 15" steel wheels before you start rubbing on the tie rod end. And it's really tight.
