How much backspacing with 42" before contact?
Discussion in 'The Garage' started by eldon519, Jul 19, 2002.
  1. eldon519
    eldon519 1/2 ton status
    May 27, 2002
    161
    Kennesaw, Georgia
    How much backspacing with 42\" before contact?
    I'm right about to order my tires and I want to have as much backspacing as I can because I'm gonna be running 42" with a 6-inch lift and there is gonna be lots of trimming. My question is, how much backspacing can I have with 42" tires before the tires will start rubbing the leaf springs, steering box or anything else at full lock? Would 4.5" be too much? 4.75"?
  2. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: How much backspacing with 42\" before contact?
    Backspacing is a function of rim width, not tire diameter. You need to know how wide your rims are, then determine backspacing and how much you want to stick out past your body and how close your steering components are. The rim sales guys can tell you what will fit and what won't. It is the distance from the center of the rim to the inside edge of the rim. You will want a different backspacing depending on your rim width - 8", 10", etc.
  3. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    You're right about all that but backspacing is also largely responsible for determining how close the inside sidewall of your tires is. If your tire diameter gets large enough and you have too much backspacing, the inside sidewall of your tire can come in contact with leaf springs, powersteering box, etc. I'm gonna run 15x10" rims but width doesn't have too much effect on the contact of the inner sidewall, that more has to do with hitting your fenders. Anyone out there running 42" tires with a 6" lift, how much backspacing do you have?
  4. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    contact Billyray on this one. I think he is running a 6 inch susp. and 42s
  5. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    i'm running 42's and 6"lift. on 16.5X9.75 with 4.5 of backspacing.no clearance problem.welcome to the 40 and up crowd!
  6. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Thanks for the info efilnikufecin, that's exactly what I needed to know. I was planning on running 4.5" on a 15x10 and just wanted to make sure they cleared before I ordered. I've been waiting nearly a week to figure this out so I'll be placing my order tomorrow. Again, thanks for the info.
  7. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Sorry it took so long. I have been working my but off at work then when I get home I'am wourking on the truck.
    The back space on mine is 3.5 that way I did not need to grind so much off the calipers. It also makes the truck a little wider so the tires could give it a little body protection.
    Again sorry I did not get right back to ya. On a normal week I would just stop what i'am doing and check for ya. /forums/images/icons/crazy.gif
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Stepen at ORD is running a 16.5x10(i believe) with 5" of backspacing!
  9. eldon519
    May 27, 2002
    161
    Kennesaw, Georgia
    Hey Billy Ray, thanks for checking that out for me. I know things can get hectic when you gotta work on your rig. If I remember correctly, you run a 15" wheel on a 1-ton drivetrain and you ran 3.5" of backspacing so you had to grind some right? Do you think it would be possible to run 4.5" of backspacing or would that be way too much grinding and compromise the strength of the brakes?
  10. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    Man you will have no problem at all. You just get to have more fun GRINDING!!! /forums/images/icons/wink.gif
