How much bigger is a 14FF housing than a 12-bolt? (axle tube not diff)
Discussion in 'The Garage' started by Topdown, Apr 14, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok... I dont have my 14FF yet, but it will be here in a few weeks.
    So, those of you with 14FF's, did you notice any "lift" difference after installing the 14FF? I mean, if the axle housing is 1" "taller" from center than the 12-bolt wouldnt that equate to your tire sitting 1" lower in your wheel well? (essentially a lift of sorts)
    Just trying to figure out what to expect and if I am going to need to "lift" the front (D44) a little (1/2 inch or so) to compensate for the bigger rear axle housing.
    -Ryan /forums/images/graemlins/k5.gif
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    It does lift it a little. I don't know if you looked at mine at the pizza place but it used to sit level now the rear is about 1-1.5" higher than before. Most definately noticeable but not too horribly raked.
  3. DwarF
    DwarF 1/2 ton status
    Mar 29, 2001
    226
    Austin, Tx
    I thought the 12 bolt was 3" diameter? My 14bolt is 3.5", which would equate to a half inch in both directions from the center. I doubt you would notice.
  4. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    that would be a 1/4 inch top and bottom....
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Actually, the tubes are 3 3/8" diameter. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep, Wes is correct(of course) the 14BFF is 3-3/8" diameter and the 12 bolt is 3" diameter, netting about 3/16" lift from the tube diameter. You probably won't be able to notice 3/16" but you might if you have a calibrated eye. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I did get a little lift out of my 14bff when it replaced the 10 bolt. I got the little lift off the axle tube being bigger, but I think I also netted some off the spring perched being taller too. I don't think I got a full inch, but I would say between 1/2-1" total. My buddy who helped me install it both noticed the little extra raise.
  8. Topdown
    Nov 26, 2002
    2,598
    Thanks everyone!
    -Ryan
