How much cutting for 38s?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Oct 9, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I am looking into some 38x14.50 or 38x15.50 for my Jimmy. It has a tuff country lift on it with 4" springs in the front and 6" in the rear. It sits about level now at about 5.5" because I have no top, doors, or windows. Anyways I was wondering how much cutting I will have to do, or what size should I go with (bigger than 35s)?
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  2. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I'm running 42's with a 4" lift
    Cut out a nice amount, and requires the removal of the fender wells, front and rear. I cut way more than I needed to on both
    My buddy is running 38.5's on his burban with a 4" lift with the trimming from the tech section, but they are real close
  3. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Would 37s be a better choice then? I want to keep my rear wheel wells. I want to go as tall as possible because when I air down I loose alot of ground clearance with my 35s (actually measured 34" when fully inflated). I am only running 1/2 ton axles (10 bolt front, 12 bolt rear) so I wont go any bigger than 38s. I know you guys say 37 or 38s are too big for 1/2 ton axles, but I probably weigh under 4,000 now.
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    top
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i dont think you are losing that much. I ran 35's with my 1/2 ton gear and never had a problem. I have a problem now cuz i have 36's with a 14 bolt in the rear...
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] MOAB 2002 OR BUST!! [​IMG]
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The bottom of my old 10 bolt rear looks loke I shaved the bottom off, thats how bad I have hit it. I need a few more inches to help clear.
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I think if you cut like steve did you could run 37's. Steve has about 4" of lift plus ORD shackle/D60 front that gives another inch and then he has the ORD zero rate in the rear I believe... so 5" all around. I'd say cut as much as you feel comfortable with and get the tires... then try and find a ramp or a forklift to check stuff out. If you need more a 1" ORD body lift should clear em.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I found a set of four 38.5x14.50x15 tsl sx with a 38x12.50x15 tsl sx for $700. They have over 3/4 of the tread left also. I just want to know how much before I buy them and decide I have to cut too much.
  9. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    I run those exact sx tires with a 4" lift with no probs but i did do alot of fender trimming but nothing totally extreme and no i dont rub.
    350, sm465, NP205, 14ff w/detroit, yucky ten bolt 4" springs,38.5x14.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  10. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Did you have to get rid of your inner fender wells or did you just trim them, or move them back? BTW how do you like those tires?
  11. 77Blazer
    Aug 13, 2001
    197
    Long beach CA
    I just did all the trimmin i could while leaving the inner wheel well in tact. As far as the tires go I have had them since feb of 2000 and they still have 3/4's of the tread left and they kick butt in the mud. Boggers are next though only because my blazer wont be my daily driver as of next month otherwise i would be sticking with the sx's
  12. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Any body else run these tires and this lift? Or just the on the tires, how long do they last mileage wise?
  13. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I just put 38.5"x14.5" sx's on my k5 with about 4" of lift. I cut the leading and trailing edge of the front inner fenders out and welded in some sheet metal in at a better angle for more clearance. The fenders are cut, but nothing excessive. I think you could put at least 40" inch tires in the back without having to screw with the inner fenders.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  14. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats good to hear because I want to keep my back seat. I think I will be getting them.
