how much do I need to lengthen the front driveshaft?
Discussion in 'The Garage' started by Russ1020, Jan 22, 2004.
  1. Russ1020
    Russ1020 Registered Member
    Jan 20, 2001
    37
    Gulf Coast Texas
    Is there a chart or conversion table that tells how much you need to lenghten your driveshafts after a signifigant ammount of lift. I have a 1977 K10 with 7" of suspension lift and 3" of body. The curent front driveshaft is 10" from weld to weld and I am geting a new drive shaft made so I would like to lenghten it to be safe, but Im not sure how much?
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    All you need to do is mesure the distance between the mounting points /forums/images/graemlins/thumb.gif of your driveshaft and give that measurement to the DS shop.
  3. Russ1020
    Jan 20, 2001
    37
    Gulf Coast Texas
    I relly dont trust these guys to make the adjustments for me, this shop is here in houston, and Its verry affordable, but they are more of a cut weld and ballance shop. I asked them about where I need to grind on the CV joint to that the shaft wont bind any more and he had no Idea what I was talking about. They do good work as long as you tell them exactly what you want. I just had the rear shaft done ( had to change yokes because I went to a 14 bolt rear ) and it turned out good but again I had to spacificly tell them what I wanted and make sure it was done like that. What Im looking for is someone who knows a general ruel like 6" of lift equals 1" of driveshaft for example.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Time to find another shop, period. If they can't even help you measure the working length of your driveshaft, you surely need to find a different shop to work on your driveshaft.
    All I did is tell my guy 52 1/4" is the length I need, and that I needed 1350 joints in both ends of the shaft, and three hours later I got a call that it was done, balanced, U joints installed, and ready to rock.
