how much do I need to shim?
Discussion in 'The Garage' started by jekbrown, Aug 17, 2004.
  1. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I have a HAD cv shaft in rear of my rig, but my pinion angle isn't all that great. I don't get vibes much, but I do some around 45 mph and I'd like to eliminate em if at all possible. Anyway, a spring shop near me makes really nice steel ones any angle ya want so I wanna get a set. How exactly do I measure so I know what shims I need? I know there was a REALLY usefull post about this but I have searched for like 30 mins and cant seem to find it. Anyone have the info or a link so I can get this taken care of? I'd appreciate it!
    j
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    the pinion at the rear end should be about 2* lower than the driveshaft for a cv shaft, so just get a angle finder and put it on the driveshaft and say it is at 20* and then put it on the pinion on the rear and say it is 12* then you would need a 6* shim to make it at 18*, the pinion will rotate up which is why it needs to be about 2* lower than the driveshaft, hope this helped.
    -Chris
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    i dont have an angle finder... time to whip out the protractor, some string and all that poop I guess. lol!
    j
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I have to get my angle straightened out too but it's gonna need more than a shim. I have a 5* in there now and it not even close. I need to cut off and reweld the spring perches
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    j
    Angle finder, magnetic type, is $9 at home depot!!!!!!!
    If you have any questions about how to measure your driveshaft angles, I spent 114 minutes on the phone with Jesse from High Angle today, I will be glad to help you out, I'm now a self-proclaimed expert.
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    and driveshaft awareness monitor /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If you managed to trash one of Jesse's HAD's you'd feel bad enough to want to be the driveshaft awareness monitor too.
    I wish I'd known how to use an angle finder and bought one a LONG time ago. I bet I could have placed so much better at RTC if I'd only had driveshafts that would stay together, and this all could have been easily avoided if I'd simply checked my angles the right way.
    I probably wouldn't run a shim, but you can. Just cut the spring perches off and re-weld them.
