How much do you have in your 14 bolt?
Discussion in 'The Garage' started by BigJohnson, Feb 11, 2004.
  1. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    My 10 bolt w/gov-lock is on its last leg. Can you imagine that! So I really want to pick up a junkyard 14 bolt and dana 44 and replace my axles. Problem is I am on an extremely tight budget. So, what did you guys end up investing in your used axles to get them up to par? I know this has everything to do with initial condition and such but I am just looking for ballpark figures on commonly worn parts like seals, bearings, and maybe breaks.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I bought my 14 bolt for $95 then just redid the brakes and that was it. I used the same bearings and seals and it's still in mytruck with no problems for the past 3 years. I did add the detroit but you don't HAVE to.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I have about $400 in mine with 4:10's and a Detroit.
  4. blazerdude69
    blazerdude69 Registered Member
    Jan 10, 2004
    22
    I bought my d44 and 14ff for $400 pulled the calipers off the 10bolt front bought some brackets for discs for 39.95(not the right ones for 14 bolt but with a couple pieces of metal from work they work) new front brake lines that went on the rear disc for 14.95 each(?) and bolted them in.also bought d44 front rotors(for the discs on rear) and reused the wheel studs on the rear. think they were like 30-40 bucks apiece.I did pull the carrier and weld up the spider gears though. about $20 for gear lube and gaskets an had to replace one inner seal on rear hub. hope this helps. if not just ingore me. /forums/images/graemlins/smile.gif
  5. wolfy87
    wolfy87 Registered Member
    Jan 30, 2004
    32
    near Dallas, TX
    And don't forget a new set of 8 lug wheels, ujoints etc etc etc etc. Then get ya some 44's, butcher up the fenders so they'll clear, take the doors off, weld in a monkey cage, and go finish it off by bashing some rocks. Then good luck if you should ever decide to sell the tractor. /forums/images/graemlins/peace.gif
    Just being cynical. I'm a K5 enthusiist that likes to keep my rig more intact and under 10k lbs.
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Purchase price = $75
    Seals, Bearings, etc = $85
    Rotors = $50
    Disk brake brackets = $75
    A-tron hose kit = $62
    Calipers & pads = $45
    Misc, bolts, paint, etc = $30
    Grand total = $422
    Still need a Detroit = $375 and HD cover = $125
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Hmmm
    5.13s - about $160
    Rebuild kit - shoot, I forget, maybe another $150...
    Open carrier - $free.99 from tRustyk5 /forums/images/graemlins/waytogo.gif
    spring perches from Rockjunkies (iirc)- $50
    Disc brakes from Derbinator (iirc)- around $200 with all the fiddly bits
    shock mounts - $free.99 prototypes from Tony P /forums/images/graemlins/thumb.gif
    Axleshaft bolts - $free.99 from That K30 Guy /forums/images/graemlins/woot.gif
    New U-bolts - $30 or so
    Spring plates - $free.99 prototypes from Willyswanter /forums/images/graemlins/peace.gif
    Welded diff - $$free.99, done by Mr Welder himself, KidJethro.
    So around $590 out of pocket, but I'm going to be adding a Detroit to it pretty soon hopefully so it will be around $900 all said and done. Considering what it has in it, I guess it's worth the money...
    Thanks to everyone that helped me with parts for it, please note that no fewer than 7 CK5 members contributed parts or labor to this axle, and of those 5 were freebies. /forums/images/graemlins/thumb.gif Did I mention that CK5 rules? Sorry if I forgot anyone... /forums/images/graemlins/dunno.gif /forums/images/graemlins/doah.gif
  8. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    14bff axle $50
    Detroit $320
    Bearings $50
    Disk brake brackets $60
    calipers $11.99 ea
    rotors $35 ea
    Press and turn rotors $25
    I should have done a gear change...
    but I stuck with 4.10's...
    The next one...I'm shaving 2" off...and going with 5.13's /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    I got mine for free and haven't started on it yet. Just got a set of 4.10's for $40.... So I have $40 into it so far! /forums/images/graemlins/thumb.gif
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    bout $300,4.10's with a detriot and disc. /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  11. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I bought a 78 3/4 ton for 400.00. After i sold the tranny/t case,Meyers plow, and misc garbage, I made 250.00!! New locker, new gears, bearings and seal, 600.00. Throw in the disc brakes and non caddy calipers for another 140.00. grand total- 490.00
  12. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Purchase price = $100
    New bearings and seals = $100
    Welded diff = free
    disc brake brackets = $100
    calipers = free
    rotors = free
    brake hoses = $40
    u-bolts = $50
    conversion u-joint = $30
    8-lug front hubs for the 10-bolt = $50
    15x10 8-lug rims = $150
  13. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Well le'me see here: /forums/images/graemlins/thinking.gif
    14bff w/factory limited slip - $100
    New 8 lug 16" rims - unknown at this time /forums/images/graemlins/thinking.gif
    New 16" tires - unknown at this time /forums/images/graemlins/thinking.gif
    new front 8 lug setup - $150 (10 bolt 3/4 ton setup bought at a junk yard)
    new 14bff 4.10 gears to mach front diff bought at junk yard - about $50
    Sorry, i guess i can't really help out much yet, as i haven't had the cash to actually buy everything to get it runnin for the trail use. /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
    /forums/images/graemlins/burb.gif
  14. 4xcrazy
    Oct 31, 2003
    9,472
    5
    If your lookin to upgrade everything, and plan on takin it off road alot, doin some funky stuff, /forums/images/graemlins/peace.gif it will cost you some money as i am finding out, but will be worth it when completed. /forums/images/graemlins/waytogo.gif But if you want to save some cash and don't really take the ride off road much, or don't do anything extreme, then just have it rebuilt and install some kind of good locker unit in there. /forums/images/graemlins/waytogo.gif Just my opinion though. /forums/images/graemlins/doah.gif
  15. BigJohnson
    Jan 22, 2001
    207
    AL
    Thanks for all the replies everyone. I guess I am convinced...not that it was that hard...I need to go ahead and junk my 10 bolt. Adding up the average figures it looks like if I find the right axle I could end up with a 14 bolt and a detroit for less than $500. Since I need to re-gear anyway(3.08 gears are worthless) I think it will be cheaper to do the axle swap. I figure for the 10 bolt $160x2 for gears $200 for install kits and a couple more hundred to replace the gov lock with something and a brake rebuild...well you get the picture. So I guess now all I need is some axles....I'm off to the for sale forum.
  16. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hmm lets see never added it up.
    14B-$75
    4.11 gears and carrier with Detroit-$85
    Install kit-$100
    Ax-Kickin Brackets-$80
    2 Calipers-$30
    2 Rotors-$50
    16 Studs-$35
    Conversion joint-$25
    Bearings and seals-$65
    Bedliner, paint, and fluids-$50
    Daayuum $595.00 /forums/images/graemlins/yikes.gif
    Having a locked disc brake axle that's almost unbreakable.............. Priceless
  17. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Axle: $200
    4.56 gears: $200
    Install kit: $100
    bearings: $100
    Brake shoes: $35
    Ujoint: $30
    Gear Oil: $30
    Weld Spiders: $20
    Gear install: $100 + old 10 bolt
    About $850 all said and done with all new bearings, brakes, gears, etc.
    Harley
  18. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    14FF with 4:10s, free.. welded spiders.
    D44 8 lug 4:10 $200
    15x10 8 lug wheels $92
    Whatever the u-joint cost.
  19. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Where are y'all getting your bearings and seals so cheap? I priced them in LMC (because I know they are factory parts) and it came out to quite a bit more than that. I know I want Timkin bearings and high quality seals (I dont know of any brand names). I'm doing disks and the works too /forums/images/graemlins/waytogo.gif
  20. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Where are y'all getting your bearings and seals so cheap? I know I want Timkin bearings and high quality seals
    I went to Autozone. They sell Timkin. /forums/images/graemlins/waytogo.gif
